Can only engage PTO with engine Off? Farm Pro 2425/JINMA
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA
Well it'll have to wait. Accidently shorted starter in gear. Pinned and ran over me. Care flighted to uk hospital for now.
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA #13
Bad News for that as a lot of old farmers dont get any older because of this exact happening.
Hope all is well.
M
Forgot it was in gear. Thought I could snug the solenoid nut without touching anything else. It momentarily shorted and learched forward. Imeditly rolling into leg and pinning me. The wrench was dropped clear, but solenoid somehow started engaged? While using me as a speed bump, it repeatedly learched forward about every 5 seconds. First going over my bent left leg and finally onto both legs And hip. Seemed like I was pinned 2 minutes as it chomped away at me and pushed up against a 10' secured gate in middle of barn. Once cleared I pulled myself up by hands to knock out if gear. It inedible went into reverse for round two :(. I was able to quickly find neutral and call 911.
I now have a brand new total hip replacement among other injuries.
This maybe needs its own post as a warning how fast things can go wrong and how you can't be too careful.
In a positive note I did get the clutch adjusted & working properly before this happened. I ky now in not sure I can keep this tractor to be reminded. It keeps flashing up like a horror movie.
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA #16
Wow. Sorry to hear about your injuries, but glad you lived to tell the tale. Many don't.
Here's to your speedy recovery.
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA #17
I have a question on those tractors, do they have a manual fuel shutoff pull cable, or is the throttl epushed forward, or is it key on / off fuel shutoff?
It has pull fuel shut off. Keys weren't even in it. It never started. Starter pulled it across me slowly.
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA #19
wow... something must have stuck in the solenoid if it stayed engaged.
i wish you a speedy recovery.
   / Can only engage PTO with engine Off? Farm Pro 2425/JINMA #20
I am always holding the clutch pedal down by hand and starting my tractor. Before I do this however I always put the shuttle shift into neutral, Main shifter into neutral , and high/low shifter into neutral.
My grandfather had the safety switches bypassed on his 100HP Ford/new Holland tractor and started it in gear, luckily it knocked him back instead of running over him and eventually got tangled up in enough fence wire after taking out a few fences to get stopped. He was in his 80's at the time.
Tractor safety cannot be over stated.
Cleat
Charlotte County (A50323)
Charlotte County...
25"x 10" Kubota RTV-X1140 (A52377)
25"x 10" Kubota...
Bush Hog 20' Mower (A50123)
Bush Hog 20' Mower...
2008 Nissan Titan Crew Cab Pickup Truck (A51692)
2008 Nissan Titan...
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
