Rope suggestions and help
   / Rope suggestions and help #1
Rat Rod Mac
This is probably the strangest question ever posted on there, but here goes. I need a rope. One that I can tie up on a tree before I cut it to help pull it in the direction I want it to go. By fastening it to the draw bar and putting some tension on it. So what kind of material should the rope be made of, nylon, polypropelene, etc, etc. And another thing, what size diameter should it be for this application? 1/2" or 5/8" or 3/4" ??? I'm thinking about 150' should do it. Any suggestions. RRM
   / Rope suggestions and help #2
If you can tie the rope up high in the tree it takes a lot less pull than you think. You have leverage. What size tree is it, 150 year old oak and a 10 year old oak are 2 different things. Pulling to hard can splinter a tree and cause it to kick back toward the cutter.
   / Rope suggestions and help #3
An average CUT tractor draw bar can probably pull about 2000 lbs before the machine looses traction. Probably 1500 or less if the rope angle is more than 15-20 degrees. I would choose a rope with about 2000 lb working strength as a rough estimate. Three strand twisted nylon is usually the best strength to cost. 5/8th or 3/4" would do. I'd use 5/8 and just put reasonable tension rather than pulling until the tractor lost traction. The leverage of having the rope high in the tree needs to be balanced against the upward pull that diminishes traction.
If you know your tractor motor torque and drive gear reduction and wheel size you can calculate straight line drawbar pull. HowStuffWorks "Calculating Drawbar Pull". This doesn't take traction into account though and the upward pull of the line to the tree would affect that.
This link shows very conservative working load limits. You wouldn't have any shock loads like a boat mooring line or anchor line so could reasonably exceed these by 25-50% without much worry. Rope Safe Working Load - BoatSafe.com
   / Rope suggestions and help #4
We just did this last weekend, I used 1/4" x 100' steel cable, I bought two but only needed one. It was only $37 each at Home Depot and is much safer than rope. It has a loop on one end and the other is loose, I put a chain hook on the other end.
I attached the cable (wire rope) about 20' up and attached the other end to the 4wd. I cut my hinge and as I was finishing the back cut we tensioned it and as the cut was near finished amd the tree the truck pulled it the rest of the way. It took a coordinated effort but was otherwise very easy. This old dead Oak was about 20" in diameter at the cut. It worked as it was supposed to.
   / Rope suggestions and help #5
Be advised, as others mentioned, when you start pulling on a tree, your putting force into the trunk that makes the trunk want to barberchair. So: 1) Don't pull too hard. 2) For the back cut, consider making a plunge cut behind the hinge and cutting away from the hinge to the holding strap. 3) Consider wrapping a chain around the trunk just above where you're cutting so that if it does start to barberchair, the chain holds it together.
   / Rope suggestions and help #6
I had a MIGHTY ponderosa pine -36 inches on the butt - that I was going to do that trick on. The more I thought about it - the more it worried me. Fear of pulling the tree over on my new tractor, etc etc. Its only me out here so I try to be fairly careful about the more crazy things I do. I ended up tying my small Stihl around my waist, on a rope, and slowly climbing the tree. The tree was 85-90 feet tall. I fell it in chunks - from the top down. Getting the top 20 or so feet was the most difficult.
Anyhow - when pulling with the drawbar I have 50 feet of 1.25 diameter braided nylon rope. Its extremely flexible, provides a nice amount of tension simply by stretching and due to its diameter is easy to undue the knot when the job is finished.
   / Rope suggestions and help #7
I don't have any trees more than 60-70 feet high with most being 50 or less so I don't need 150 feet of whatever material. I have the chains that I use for trailer tie down and a 20 foot nylon tow strap + a chain from my BIL for 80 feet total. I usually put the tow strap on the tree because it is so light compared to a 3/8 chain. 20 feet high is plenty for encouraging a tree to go where you want it.
Don't pull to hard or you may snap the tree in half. We did that with a pine that had hung up in neighboring tree branches, kept pulling harder and harder to try to dislodge it and finally the pine broke at the strap tie point. We didn't pull it out of the branches but the break dislodged it and it came down so mission accomplished.
It would have been a very different story though if I had been chain sawing on the tree when it broke, I might not have been here to type these words if that had happened.
   / Rope suggestions and help #8
Also rather than plunge cut, try using some plastic wedges behind the cut to force the tree where you want it, then no ropes are needed unless it is a hard leaning tree and you want it to go backward from the lean. Wedging is best using a second person to keep pounding them in so they are tight all the time while the other person continuously cuts.
In case of leaning trees, make sure you have enough power and weight with the pulling machine to force the tree to go where you want it. It could end up with the puller turned into the pull-ee. That might be a wild ride being pulled backward while hooked onto a falling tree.
   / Rope suggestions and help #9
+1
On reading your admonition, the scene at the end of Dr Strangelove when Slim Pickens is riding the bomb and waving his cowboy hat popped immediately to mind.
   / Rope suggestions and help #10
1) Double braid polyester is good rope - low stretch, UV resistant & very strong. It's also good knot tying rope.
5/8 diameter serves me well with a 6000 lb tractor. The Dynema/PTFE rope ($$$) is supposed to be the cat's whiskers, but I have yet to get my hands on any.
2) Add ballast as needed to generate greater traction/pulling force.
3) Use a snatch block to redirect the load direction away from your body and to pull the rear axle down instead of up.
4) Pull from the axle mounted drawbar and drive directly away from the snatch block to avoid putting side/tipping loads on your tractor. Make sure you have a clear, safe path in that direction before you start the pull.
5) +2 Yeeeeeeeeeee Haaaaaaaaaaaaaw!
   / Rope suggestions and help #11
Like others wrote - How big is the tree?
Writing
makes me think the tree is BIG and TALL.
If you can climb and chainsaw safely I'd strongly advise pruning heavily, even if it has a clear fall area all around. Prune only on the side opposite the preferred fall direction, so it "wants to" fall on the heavy side.
Give us a picture of the tree and we will give more advice, but if you need 150' of rope we are just guessing how much you are trying to pull. Also how much pulling force can you put on it? Can you use a little more rope and fasten a pulley so you are well out of the direction of fall?
   / Rope suggestions and help #12
...and keep in mind that the elasticity of cable or rope when it snaps. It can come back at you and take your head off. That's why pulling with a snatch block has advantages (so does using a skidding winch with a protective cage).
   / Rope suggestions and help #13
I like stretchy rope to encourage a tree, but usually use a hand winch, not a vehicle, to apply tension. A no-stretch steel cable quits pulling as soon as the tree moves. A stretchy rope continues pulling for a few feet.
Bruce
   / Rope suggestions and help #14
I pulled on a birch that was leaning over the house by the electric line. I went part way through, then pulled it to get the lean correct- then cut through. At one point my front end on the tractor started to leave the ground. I was in 4 wheel drive. I backed off. I didn't want to check if the rops was solid!
Good luck. I had a 100 ft of 3/4 nylon that I was using.
   / Rope suggestions and help #15
About 20 years ago my in-laws were trying to direct a tree with a rope tied high in the tree and to the back of their pickup truck. As the tree started to fall, it pulled the rope so tight it snapped and flew back into my mother-in-law's leg. She dropped like a sack of wet cement and stayed down for several days with deep bruising in her leg. Lucky it didn't hit higher up on her body. So, lessons to consider. Think it out before doing it. ;)
   / Rope suggestions and help #16
By design, some rope stretches and some does not. I won't use rope to pull down anything. I use either chains and/or wire cable attached to a come along. The come along is nice and slow so I can see how things are going AND I can feel what is happening. I tried to help a neighbor pull out a log with my tractor using climbing rope. I told him that rope was designed to stretch if the climber fell and it was not likely to work but I would go get some chains. He insisted on using the rope which did not work. :rolleyes:
I might be paranoid but when I was a kid, I saw two guys cut down huge pine tree in a pine stand next to a trailer. They hooked up a cheap rope to the back of a truck, cut the tree a bit and started driving the truck. I told my dad this was not a good idea since if the rope was not long enough someone was going to die. One of the stupidest things I have seen and I have some seen some really dumb a...ssed stunts. Luckily the rope was long enough but just barely so. These guys might have inspired Dumb and Dumber.
Later,
Dan
This is not a one tree deal. The Emerald Ash Borer is coming through and I have a lot of ash that is going to die and I want to keep ahead of it for firewood. The trees are not that big maybe the largest is a foot in diameter, but sometimes they are leaning the wrong way and you want to redirect them a tad. The snatch block sounds good and the guy with the idea of the rope stretching a bit to stay tight as the tree starts to fall sounds like a good idea. Not trying to set the world on fire or take any chances, but sometimes you need to put a little tension on the tree. RRM
   / Rope suggestions and help #18
I don't use a rope or a chainsaw, just push them over with the V417 :thumbsup:.
This is a dead oak that was 40' tall, 17.5' diameter, 3' from the ground. Put the stump bucket on the trunk about ten feet up and slowly extended the boom. the roots broke on the west side.
Extended the boom all the way, while curling the stump bucket down.
The top of the tree was on the ground, the rest of the roots did not break.
Went to the south side, lifted pulling some roots loose.
Went to the north side, pulled it up.
Picked it up later with the grapple and put it on a brush pile north of the fence.
   / Rope suggestions and help #19
That was one rotten stump waiting to kill someone. That's the funny thing about big oaks... you never know if they're solid or rotten. Anytime I see that hollow fairy hole at the bottom there's a pretty good chance the thing is hollow and full of carpenter ants several feet up. When I was a kid, we lived on a little over an acre with close to 60 large oaks. Every year it seemed one or two would come crashing down in a thunderstorm. Used to scare the bajeebers out of me!!! :shocked: I vowed that when I was old enough to own my own home I'd never have a tree large enough to crush my house anywhere near it. In my current woods, there are several dozen large cherries that are also widow makers. I stay away from them and am happy anytime a storm takes one down.
   / Rope suggestions and help #20
That was one rotten stump waiting to kill someone. That's the funny thing about big oaks... you never know if they're solid or rotten. Anytime I see that hollow fairy hole at the bottom there's a pretty good chance the thing is hollow and full of carpenter ants several feet up. ---------------
This one hadn't been dead very long. Had the fairy hole, but wasn't rotten or hollow yet.
There is one across the driveway that is hollow. all the big limbs have fallen off. But honey bees are using it, so I will let nature take care of it.
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
