Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #231
In France do the green tractors have the name Jean Deere painted on them? :)
   / Tractors and wood! Show your pics #232
   / Tractors and wood! Show your pics #233
Here's this weeks fun--
   / Tractors and wood! Show your pics #235
Here is a all night log for the fire. Who says full size grapples cannot lift logs.
   / Tractors and wood! Show your pics #236
Just had to split it and check out the inside100_7640.jpg Going to move this to the side and let it set for another year... what a gooey mess :)
time to re-sharpen the huskys chain:laughing:
   / Tractors and wood! Show your pics #237
Occasionally, I'll go after a deadfall.
But usually, I get an 8 cord load of tree length delivered
Then I browbeat my daughter and grandkids into helping me split it.
And my Brother-in-Law and I stack a year's supply undercover.
But I try to stay a year ahead so as to have plenty of seasoned wood.
And I'm enjoying it right now! :dance1: :thumbsup: :laughing:
I'm curious about the small tractor in the first photo. I saw it once at a farm show and wondered what it was designed for. Could it be solely for moving things around the farm?
   / Tractors and wood! Show your pics #238
It's a vineyard tractor. Deere rebaged them from a European company. The model that deere had was air cooled diesel with articulated steering.
   / Tractors and wood! Show your pics #239
This is a Gif shot from 1990 the log is 20 inch 50 cm x 20 inch 50 cm
we made this hydraulic firewood machine of old waste materials
it was the first of its kind with twin or tandem cylinders
normally it is run with the lowest cylinder 5 t. 250 bar
3 sec. forward 1 sec. return
with 2 cylinders it makes 10 t. and runs little slower
the 12 mm thin knife is made of Swedish hardex 400 steel and it has the strength of 30 mm ordinary steel
the cylinders and pistons are all made of plast not stainless steel
and it is driven with ordinary water (water hydraulics)
it has served us fore more than 20 years and is still going strong
and guess what the hydraulic pump is ? ;)
   / Tractors and wood! Show your pics #240
Hi Svendus, that is brilliant.
You've a hose from the house tap and an inline water-pump perhaps?
Air compressor?
Must be massive amounts of force on the wedge welding given how high it is, even if the wedge is tilted forward (and thinner), limiting the resistance. I do like the concept of wedges being knives rather than relying solely upon brute force, provided you've got a long enough knife to not have to worry about pulling the wood pieces apart, and the thin knife is strong enough to take any twisting loads.
Do you still have the machine? How many cubic metres of wood did it split and what failed, if anything, on it first?
This is a really clever idea. Love it.
*edit*
Some googling came up with this:
SNIK KLYVEN
and a slideshow here:
SNIK VEDKLYVEN
so I guess it's powered by a waterblaster/pressure washer/ whatever you want to call it.
The Sunday sawmill is another clever idea. Same people or person behind the two designs? Is there more info' I could read to learn about them please?
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2013 Chevy Silverado 2500 HD (A53472)
2013 Chevy...
UNUSED AGT 3000 PSI HOT WATER PRESSURE (A51248)
UNUSED AGT 3000...
2007 IC Corporation PB105 Passenger Bus (A51692)
2007 IC...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
