rbargeron
Elite Member
I looked carefully at the Illustrated Parts List at K's website and found that the 2-stages of the L235's dual clutch are NOT adjustable like some other models.
The single-clutch and dual-clutch L235s actually use two different clutch housings. The dual-clutch model has a deeper housing. Unfortunately dual-clutch model doesn't have a window in the side for clutch adjustment. My L345DT with dual clutch doesn't have an adjustment window either. When the travel clutch gets worn the only solution is splitting the tractor and replacing it. Ironically, with the tractor split, there's good access for adjusting the dual clutch - buying a couple years more use. It makes more sense to just replace the worn travel disk while its apart.
