Check the spare tire carrier
   / Check the spare tire carrier #22
My former neighbor had the spare fall out of his Excursion. Found it in the driveway after his wife took the truck..Cable broke..They we lucky on that one.
I removed the winch and noticed part of the housing was broken, so I just purchased on ebay a whole new winch system for the spare.
Bob
   / Check the spare tire carrier #24
Easy solution. Buy a dually. I have 2 spares wherever I go already bolted on. They took my winch out putting in tank and motor for hayspikes. On any given day I use a lot of my bed space so I generally leave the spare at home. If I am pulling a heavy trailer and/or going more than 50 miles from home I will toss it in the bed.
Exactly, rolling spares. Ya need 4 tires to get home in an emergency, a dually with a spare is 7, so you can get 3 flats :)
   / Check the spare tire carrier #25
Couldn't agree more. Plus I used to have a 3 legged dog and he got around just fine.
   / Check the spare tire carrier #26
I had cable break on my '86 Chevy S10 4x4, back in '88 or so. Was washing the truck when I saw cable hanging down.
Used to go playing in mud holes; guessing it happened in a mud hole and I never knew/noticed.
   / Check the spare tire carrier #27
If the spare fell out of an Excursion, the back doors would have to come open first because the thing is mounted inside the vehicle.
   / Check the spare tire carrier #28
It's is a good idea to check spares. Not just to make sure they come down but to make sure they are not flat. Just replaced the spare in my 2000 because it dry rotted and would not hold air anymore.
   / Check the spare tire carrier #29
That is a good point. I like to max out the air pressure on the spare, then even if I forget to check the spare for a while, it should still have enough air.
   / Check the spare tire carrier #30
My 1992 Chevy Silverado Has one of those underneath hand crank spare tire carriers. I'm thinking of moving the spare into the bed. Would make it much more handier to get to.
Hadn't lost the spare from underneath there thank goodness. It's in the way anyway as I've got a good receiver hitch that would fit the truck if I just get that spare out of there.
I could get one that fits around the spare but why do that when I got this perfectly good hitch and don't need the spare underneath there anyway.
I always thought it was an inconvenient bad spot to put a spare. lol
24ft T/A Enclosed Cargo Trailer (A53424)
24ft T/A Enclosed...
Frontier FM2015 (A53314)
Frontier FM2015...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
2016 Ford F-150 Pickup Truck (A54814)
2016 Ford F-150...
2016 Nissan Pathfinder SUV (A53424)
2016 Nissan...
