fluid site plug L2800 Kubota question
   / fluid site plug L2800 Kubota question #1
clovergamecock
Gold Member
Clover SC
Kubota L2800 4WD FEL
The hydraulic site plug on the side of the transmission case broke off. Does anyone know the actual name of this thing or the part number I need? I have done several google searches with no luck. This is the clear site plug that shows the hydraulic fluid level.
Thanks
Wade
   / fluid site plug L2800 Kubota question #2
It is "gauge,oil", TC220-14614
L2800 w/FEL - 72" Land Pride rake
   / fluid site plug L2800 Kubota question #3
Heres a spare I keep.
I purchased one and it looked right but it appears that the hole on my 06 L2800 is smooth and not threaded like the new plug is. Is there a different part that presses in like a plug?
   / fluid site plug L2800 Kubota question #5
Are they hard plastic threads or soft rubber. It may just press in.
Hard plastic with threads. I thought is might be press in but did not want to try in case there was something else I was missing. The old one was broken at the head so I could not tell if it had threads or not.
   / fluid site plug L2800 Kubota question #7
I think it is threaded if its "broken off @ at head" back it out counter clockwise and see. You could even try inserting needle nose pliers inside exposed hole ,open up ,put presser and try to turn. If not also changing all fluid I would tilt tractor away up on site glass site side, put bucket underneath to capture fluid and save. And stick a shop vac hose in refilling hose w/vac running to hold up fluid while I'am repaireing.
when the old one broke a stick must have sheared or popped it out. There isn't anything left behind that would indicate that the old one was threaded or not. The lower half (shank) that is missing either fell out with the plug or worse case, fell into the casing itself. I have looked all over the web and the same part number consistently pops up.
Thanks
Wade
2004 30ft S/A Scissor Pontoon Boat Trailer (A50324)
2004 30ft S/A...
2014 Chrysler Town and Country Van (A50324)
2014 Chrysler Town...
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
