TSC 22 ton log splitter, problem
   / TSC 22 ton log splitter, problem #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
pulled my down position handle this afternoon and the wedge, wedged in a log.When I pushed the handle up nothing happened. The wedge is in the down position and will not respond to up or down handle motion, any suggestions ?
   / TSC 22 ton log splitter, problem #2
Sounds like your hydraulics are stalled, maxed out. Can you use a chainsaw or other saw to cut the stuck piece shorter? Between the wedge and the stop.
   / TSC 22 ton log splitter, problem #3
Like Dave1949 indicated. Free the splitter from the stuck log and cycle it 2 or 3 times. That should return things to normal.
the splitter is free. it is stuck in the down position.
   / TSC 22 ton log splitter, problem #5
OK Try this. Its possible that your hydraulic valve is stuck. Try tapping - gently - on the valve with the handle of a screw driver. This might break it loose.
   / TSC 22 ton log splitter, problem #6
Check the coupling between the engine and pump. It's a common problem.
where is the coupling
   / TSC 22 ton log splitter, problem #8
Looks like a vertical shaft engine, so the coupling would be below the motor where the engine shaft is.
is there a diagnostic test to do ?
   / TSC 22 ton log splitter, problem #10
Shooting in the dark here. :) There is probably a key or clamp on the motor shaft that connects it to the pump shaft. Look for any sign of slipping at that point. You may need to remove the pump from the motor shaft to see what's what. If that looks good, I would suspect the valve is stuck.
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
14179 (A55788)
14179 (A55788)
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
UNUSED IRANCH IRMC HIGH END ELECTRIC MASSAGE CHAIR (A54757)
UNUSED IRANCH IRMC...
2009 40ft High...
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
