OP
muddstopper
Well I'm stumped. I made a test cut and it was so square it was hard to catch a fingernail on the difference between the two ends. So, I decided to make a cut for a piece I needed for the project. No good, just as bad as ever. No two cuts the same. Through messing with it for today. I have about 8- 2.5in holes to drill and my drill only goes down to 250rpms. Did a test hole in a piece of scrap because I was afraid I couldnt drill it. About 15mins to cut thru, after drilling a clearance hole for the chips to fall thru. That will give me something to do while I wait on the bird to get ready for eating tomorrow.
I'll look at the roller guides later, I noticed that sliding them in and out, there seems to be a lot of slop. The back guide, (closest to the motor) doesnt have any adjustment, and it seems pretty far away from the cut piece. Might have to be back that far to clear the chips???, The other guide, I dont know, thats a long way to slide it and expect it to stay true. Metal arm is pretty flimsy. I might be able to take it off and give it a good cleaning, tighten everything back up and it be ok. Maybe add a shim or something. Enough aggravation for one day, will look at it tomorrow.
