any one put a stand on their 3 point scraper blade
   / any one put a stand on their 3 point scraper blade #1
sleepydeere
Woolwich, Maine
4052 R John Deere
Hi I would like to put a stand on my Lineback SO 6' scraper blade ,so when I get my pat's easy change on my 870 JD, I won't have to look for A block every time I take it off, Any info would be great Thanks sleepydeere
   / any one put a stand on their 3 point scraper blade #2
Mine has about a 1 inch ID tube, with a crossbolt hole, 3 inches long, welded to the frame near the front. In this is a rod with some crossbolt holes and a foot on the bottom. Easy and simple.
Bruce
Here is one like it:
   / any one put a stand on their 3 point scraper blade #3
U could do make a piece so that it ajusts with a bolt. Don't have any pic of what my dad had, but it was a4ft piece of square tubing and had a 3in piece of square tubing that was just fit over the other one and drilled a hole in the 3in and welded a nut over the hole and screwed a bolt into the nut. Now weld the 3in tubing to the implement and put the 4ft tube into the 3in tube. And now u have a ajustable leg for it. If u don't understand what in saying i can make a picture but u got to show me how to post pics
   / any one put a stand on their 3 point scraper blade #4
Yes I put one on mine,basically the same as in previous picture.
Thanks for the post's
   / any one put a stand on their 3 point scraper blade #7
I made one out of square tube. Welded a short piece on similar to the pix and took a smaller size about 2 1/2' long for the leg. I welded a small flat on for a foot and drilled 2 holes, one at the top to support the blade and one at the bottom to hold the leg up while I am using the blade. I put a pin thru it like in the pix. Works pretty good.
   / any one put a stand on their 3 point scraper blade #8
I made mine out of pipe. One piece slipped into a size larger. Welded a 4" square pad on the bottom. Drilled a hole thru the larger piece toward one end. Cut a hole thru the blade platform, you could vary that depending on blade design. Measured the height I wanted it to sit and then drilled a hole thru the smaller pipe at the appropriate distance to get that height. Drilled another hole thru the smaller pipe that would carry it at a height out of the way for work. Took about 15 minutes. Wouldn't be without it.
   / any one put a stand on their 3 point scraper blade #9
Hmmm- - - I use a convenient chunk of firewood.
   / any one put a stand on their 3 point scraper blade #10
I use a QH. Best part of a stand is I can sit the blade down anywhere without having to search for appropriate stick of wood. :)
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
