Ford releases fuel numbers for the new F-150
Status
Not open for further replies.
   / Ford releases fuel numbers for the new F-150 #316
Ok now you Ford guys are really reaching!!! Smallest Eco Boost engine yet!
I thought it was the battery powered F-150? Mileage is awesome!
   / Ford releases fuel numbers for the new F-150 #317
Why do you believe an air to water intercooler would correct condensation issues? I would think that anytime you drop the temperature of charge air, water would condense. The charge air is still gets transferring its heat to cooler metal in each of the two types. I agree air to water heat exchangers are better in preventing heat soak though.
I'm not a turbo designer, but I'm pretty sure normal intercooler 'cooled' air is still warmer than ambient air, after 'cooling'. That is unless you have some artificial cooling means such as ice, dry ice, etc...
   / Ford releases fuel numbers for the new F-150 #318
Air to water intercoolers don't have the pressure drop that air to air intercoolers use to cool the intake charge. No pressure drop, no water condenses out. However, the issue, as the link points out is dumping the heat put into the water requiring yet another radiator.
Water to Air Vs Air to Air Intercooler | intercooler air water FMIC
air to water coolers are still bound by the rules of air to air, that is unless you have the truck parked and the water side plumbed to a nearby lake, otherwise it's still the air temp and air volume doing the cooling. :)
   / Ford releases fuel numbers for the new F-150 #319
It is warmer than ambient but a lot less cooler than what's coming out of the compressor. Artificial cooling as you mention is popular at the drag strips and boats actually use water sourced intercoolers with Lake water.
   / Ford releases fuel numbers for the new F-150 #320
The Ram can't hold a magnet to the F150
Status
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
(2) USED 7000 LB AXLES W/ BRAKES (A57192)
(2) USED 7000 LB...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A57192)
2015 MACK ELITE...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
2020 DRAGON ESP...
2015 CATERPILLAR D7E LGP CRAWLER DOZER (A52707)
2015 CATERPILLAR...
