Grease Gun
   / Grease Gun
Not a garden tractor. CUT = Compact Utility Tractor with a total of 20 zerks.
I've got two manual grease guns that work fine. I think it would be handy to have a powered one, especially on a 90 degree day in the sun.
Maybe if you use a full tube...but still.
The OP talks of a garden tractor
   / Grease Gun #12
Whatever you get, put the LockNLube coupler on it :thumbsup:
Check this thread: http://www.tractorbynet.com/forums/oil-fuel-lubricants/304889-locknlube-cupler-grease-gun.html
And the Review thread: http://www.tractorbynet.com/forums/owning-operating/307933-review-locknlube-grease-gun-coupler.html
   / Grease Gun #13
I put a swivel tip View attachment 401928 on a pistol grip pump grease gun View attachment 401931.
It allows me to lay on my back and twist around greasing zerks one handed.
I use this tip View attachment 401929 for one odd size fitting on one wheel of my bushhog - pumping the grease directly into the zerk through the inlet hole (works on chain saw tip too).
I use this one with the tip rounded on the grinder View attachment 401930 to fit the one spot where the fitting came off and I can't find a replacement. (Two hand job-hold tip steady, pump with the other hand -grease fitting on top inside that hex.)
I have two grease guns set up, one with the swivel, one with the small tip.
   / Grease Gun
Interesting coupler. What is the diameter? My loader zerks are recessed and they did not leave a lot of room for anything larger than a standard coupler.
   / Grease Gun #16
The diameter is 11mm. Try this, go to your local auto parts store, get a zerk with the 1/8 inch pipe thread and screw it into the standard coupler that you removed.
Then lock the LockNLube on to the adapter and grease the recessed zerks!
   / Grease Gun #17
Pretty clever there X-man
Seems like a good way to give you any kind of quick change tip.
   / Grease Gun #18
I am a heavy equipment mechanic and do alot of track work. Only grease gun I would ever buy again is my milwaukee electric grease gun. Its alittle pricy but the caddilac of grease guns.
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Bush Hog 287 3 pt Mower (A50514)
Bush Hog 287 3 pt...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
