Grease Gun
/ Grease Gun #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
I want an air powered grease gun to grease the zerks on my CUT with loader.
Price and reviews are all over the map. Seems the reviews on the popular tool sites are either 5's or 1's.
I don't want a 5 gallon or larger roll around. I want an air powered cartridge gun. Will pay for quality.
Let me know what your are happy with.:cool2:
/ Grease Gun #2
Let me say first that I HATE GREASE GUNS!
When they don't stop putting out they will have grease everywhere and on me! Then there is the stopped up fittings. ARG!
I sell and repair construction equipment.
I have had good luck with the Harbor Freight Air Guns. I didn't like the single pump action.
I had to go to a gun for a 5 gal bucket because one machine that I grease regularly takes about 30 pumps in 2 places.
I bought a used Lincoln used and used it for a few years then the seals started leaking. (I tried contacting them by email, got NO response)
I recently bought a Graco used and am happy with it.
The prices are INSANE on the commercial units!!!
/ Grease Gun #3
Why an air grease gun ?
Regular grease guns work fine for a fraction of the price for your needs.
/ Grease Gun #4
I bought an air grease gun at a discount tool place. Worked fine. A couple of years later the hose split. I seem to go through grease guns. I wouldn't say that quality ones are available- it is a low end tool. Good luck with it, I am interested in what you find out.
/ Grease Gun #5
Have you considered a rechargeable battery operated grease gun? They work good.
/ Grease Gun #6
I agree on that but I have a couple things that take a whole tube.
I used a cheap air gun for years, when it broke I got the Lincoln with continuous pumping and it works good.
For most greasing where a pump or 2 is need I used an old Lincoln lever gun, fast and reliable and you can grease anywhere.
/ Grease Gun #7
Maybe if you use a full tube...but still.
The OP talks of a garden tractor
/ Grease Gun #9
i love my rechargeable Lincoln grease gun, only problem is hearing that crack its loud.
/ Grease Gun #10
Lincoln Pneumatic, 1162. I have one, works great.
I believe there was an earlier version (1163?) that may have had some issues. The 1162 is current and has had some improvements
The rechargable Lincoln power lubers are excellent too, but are considerably more money than the pneumatic.
/ Grease Gun
Not a garden tractor. CUT = Compact Utility Tractor with a total of 20 zerks.
I've got two manual grease guns that work fine. I think it would be handy to have a powered one, especially on a 90 degree day in the sun.
/ Grease Gun #12
Whatever you get, put the LockNLube coupler on it :thumbsup:
Check this thread: http://www.tractorbynet.com/forums/oil-fuel-lubricants/304889-locknlube-cupler-grease-gun.html
And the Review thread: http://www.tractorbynet.com/forums/owning-operating/307933-review-locknlube-grease-gun-coupler.html
/ Grease Gun #13
I put a swivel tip View attachment 401928 on a pistol grip pump grease gun View attachment 401931.
It allows me to lay on my back and twist around greasing zerks one handed.
I use this tip View attachment 401929 for one odd size fitting on one wheel of my bushhog - pumping the grease directly into the zerk through the inlet hole (works on chain saw tip too).
I use this one with the tip rounded on the grinder View attachment 401930 to fit the one spot where the fitting came off and I can't find a replacement. (Two hand job-hold tip steady, pump with the other hand -grease fitting on top inside that hex.)
I have two grease guns set up, one with the swivel, one with the small tip.
/ Grease Gun
Interesting coupler. What is the diameter? My loader zerks are recessed and they did not leave a lot of room for anything larger than a standard coupler.
/ Grease Gun #16
The diameter is 11mm. Try this, go to your local auto parts store, get a zerk with the 1/8 inch pipe thread and screw it into the standard coupler that you removed.
Then lock the LockNLube on to the adapter and grease the recessed zerks!
/ Grease Gun #17
Pretty clever there X-man
Seems like a good way to give you any kind of quick change tip.
/ Grease Gun #18
I am a heavy equipment mechanic and do alot of track work. Only grease gun I would ever buy again is my milwaukee electric grease gun. Its alittle pricy but the caddilac of grease guns.
2016 CATERPILLAR D6K2 LGP CRAWLER DOZER (A65053)
2016 CATERPILLAR...
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
2025 TP25 25in Hydraulic Post Puller Skid Steer Attachment (A64553)
2025 TP25 25in...
86 (A63290)
86 (A63290)
215603 (A63276)
215603 (A63276)
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
