Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #361
By the way, no 3 point hitch log grapple users on here?
Here's my grapple - Wallenstein LX5100. This thing is great to work with.
   / Tractors and wood! Show your pics #364
My grapple evolved over the years as I improved it. Started with this ATI bucket grapple with added teeth
Then I adjusted the position of the hinge forward, added some curve to the tines, and added more teeth to the bucket edge
Last spring I added a tooth bar. I don't think I can make it much better now.
This one is from 2 weeks ago before all the warm weather. Loading fir headed for the saw mill.
gg
Nice tree grabber, looks like 4 bolts on each side holds it on, maybe in a couple years I'll be able to get one on mine, I hope they come with instruction's on hooking up hydraulics, cause when it comes to hydraulic rams and hoses, I'm nummer than a pounded thumb. The way I move logs now is with 2 short bolt on forks, they work, but they can be a pain, you probably already know that, and I though I was the king of modifying, I don't know how to make anything, but seams like I modify everything, I probably have way over 2 dozen modifications and accessory's on my tractor and winch.
   / Tractors and wood! Show your pics #365
That looks like a very nice grapple unit. You are just teasing us with a couple pics, What can you tell us about operating it. I see you have a winch too. How do you divide the work between the two of them ?? Thanks
gg
   / Tractors and wood! Show your pics #366
Yes, hemlock. The pic is from September I think(?) over at my neighbor's place. They cut some hemlock for our snowmobile club to have milled up into planking for bridges. We needed 8' planks, so they cut about half the logs into 8' lengths before I told them to stop. They thought there was no way a tractor could haul them out full length. The one in the bucket is one of those 8 footers.
Love the old winch, but the hitch bar is too low. You can see those big butts are barely off the ground.
What brand of winch is that, and how old is old, I still remember what tractor not to buy, on the educational TV show Green Acers.
On my Fransgard v-3004 I don't hook the chain down on that chain rail, I keep it hooked to the keyhole cable slide, Fransgard says not to do that or the sky will fall down, I'm so blessed to have the courage to do it anyways.
   / Tractors and wood! Show your pics #367
   / Tractors and wood! Show your pics #368
That looks like a very nice grapple unit. You are just teasing us with a couple pics, What can you tell us about operating it. I see you have a winch too. How do you divide the work between the two of them ?? Thanksgg
That's what I had in mind (the log grapple) when I built my winch. I think it should be real dream team. I built in a provision to hang one of them on the boom, just need to "pony up" $1200 or so and I can't spare the pony's right now!:laughing:
   / Tractors and wood! Show your pics #369
Wow that's a serious looking hitch! Any info on it?! Pretty awesome!
   / Tractors and wood! Show your pics #370
That Dodge dump truck is cool! I need one of those! (0:
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Bench Grinder (A57454)
Metal Horse Statue (A57454)
Metal Horse Statue...
(4) Ratchet Straps (A57453)
(4) Ratchet Straps...
New Holland TV145 4wd Tractor (A56436)
New Holland TV145...
Towable Diesel Generator (A59228)
Towable Diesel...
