Traded in the New Holland Boomer 3050 For a New Holland T4.75
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75
Just out of curiosity does it yell at you when its cold out like the 3050 did?? I bet you will miss that!!:)
Don't know as we have not had any weather below 32F yet.
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75 #32
There are two other items I like about this T4.75 tractor that on my Boomer 3050 irritated me to no end.
On the T4.75 I can get off the seat and exit the tractor without putting the parking brake on, the range selector in neutral and the gear selection in neutral......and the unit only alarms for 3-5 seconds and the engine keeps running. On the Boomer 3050 with CVT Transmission if I got off the tractor with the engine running and not apply the brake the engine would quit and it would audibly alarm forever. I get off my tractor constantly when picking up pecan limbs, inspecting insect traps or marking trees and having to apply and disengage the brake lever 30-40 times a hour was a hassle. I am mature enough, 61 years old, that I do not need some stupid alarm to let me know the tractor may creep/roll in neutral if not on level ground.
On the T4.75 I can place the PTO lever between regular PTO and Eco PTO and still rotate the PTO shaft by hand in order the connect the PTO shaft from any rear mounted implement. On the Boomer 3050 the PTO shaft would lock in a fixed position with the motor off and sometimes it was a huge hassle to rotate the implement PTO shaft to match especially with a spring loaded shaft collar. I am a happy camper so far......
Utopia
Is the PTO itself turned on/off by a switch or manual lever?
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75 #33
By the Way I hope you and your family have a Merry Christmas and Happy New Year
or being politically correct as my kids instruct me to be Happy Holidays
Hoping you and your family have a peaceful Christmas.
PS-I am old enough now that I don't care if I am politically correct!
The PTO is turned on and off by a new fangled contraption called a "lever". :cool:
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75 #36
Sounds like you have a wonderful wife to go along with that great tractor . I have a great wife too who always says "get whatever makes life easier" .I go along with Merry Christmas also .
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75 #37
Was there a long learning curve to using that lever???:) I assume it's a tier 4B tractor what's involved with the maintenance of that exhaust system/filter?? Every 600 hours change when your servicing the rest of the tractor as the brochures says?
Yes, she is great to me and after 33 years very tolerant of my foibles!
Might hit 32F here tonight so Winter is here though it is bright and sunny today. Merry Christmas to you and your also !
Lever works just like the one on my original tractor a Ford 8N except on the T4.75 I don't have to bend over to reach the lever. The tractor exhaust is Tier 4B and there is no maintenence. Regular fluids and filters maintenence is supposed to start at 600 hours but I will perform engine oil, engine oil filter and main hydraulic filter change at 50 hours.
   / Traded in the New Holland Boomer 3050 For a New Holland T4.75 #40
That sounds great. It's a tractor without all those unneeded fancy electronic controls a tractor that works when you need it. I'm jealous!! thanks for the info Utopia. I did find out I can order one with industrial tires though.
2013 JOHN DEERE 470G LC EXCAVATOR (A51246)
2013 JOHN DEERE...
2018 Bobcat T590 (A50123)
2018 Bobcat T590...
UNUSED WOLVERINE 66" BOLT ON PALLET FORKS (A51248)
UNUSED WOLVERINE...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51247)
2000 SCHWING P88...
TEST YOUR BID BUTTON! (A51247)
TEST YOUR BID...
2012 FORD 4 DOOR TAURUS (A53426)
2012 FORD 4 DOOR...
