JD 3320 SCV Joystick Parts
   / JD 3320 SCV Joystick Parts #1
jbbankshot
Member
John Deere 3320
I am trying to find parts for the joystick toggle switch. The issue I have it my grapple will open and not close. I did a bunch of trouble shooting and determine the the down/close button on my switch is not working. I don't think there is a separate fuse for open vs close. I took the joystick apart and there is a round electronic switch. Is this replaceable? If so, I'm having trouble locating the part number.
Any suggestions would be great!
JB
   / JD 3320 SCV Joystick Parts #2
Yes, the switch membrane is replaceable. First item on the list:
Yes, the switch membrane is replaceable. First item on the list: <img src="http://www.tractorbynet.com/forums/files/john-deere-owning-operating/404427-jd-3320-scv-joystick-parts-joystick-parts-png"/>
It would be great to see a picture, I'll search for that one.
Thanks
JB
   / JD 3320 SCV Joystick Parts #7
I guess I am invisible...good luck.
Everyone was a big help as usual! Now if one of you could make my part instantly arrive at my house, then I could get more work done!
JB
   / JD 3320 SCV Joystick Parts #10
My 4520 did the same thing. It was a broken wire, not the switch itself. The lead broke about half way between the switch and the connector where it rubs on the trim. I replaced the wire with some high quality high strand count wire and re-installed. You might want to do some checks with a multimeter to see if it is the wire or the switch itself. May save you a few dollars.
iDrive TDS-2010H...
2019 Dorsey DF40 40ft. 40 Ton T/A Drop Deck Flatbed Trailer (A60460)
2019 Dorsey DF40...
2017 KALMAR OTTAWA T2 4X2 SPOT TRUCK (A60430)
2017 KALMAR OTTAWA...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
2018 Nissan Versa Sedan (A59231)
2018 Nissan Versa...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2018 FREIGHTLINER...
