A favor to your angle grinder
   / A favor to your angle grinder #31
I discovered that on my own too.. There is nothing better to sharpen a mower blade with in my opinion. Beats the heck out of a bench grinder.
I almost never use a bench grinder anymore.
Also almost never use a regular grinder disc either unless using the "End" like grinding out a crack or weld. Always try and use some type of flapper if I can.
How do they work on removing rust and old paint? About to refinish a FEL Bucket.
Sent from my iPad using TractorByNet
Will probably work, but likely load up like any other flapper.
Get something actually made for paint. Just search paint stripping disc.
   / A favor to your angle grinder #32
I almost never use a bench grinder anymore. Also almost never use a regular grinder disc either unless using the "End" like grinding out a crack or weld. Always try and use some type of flapper if I can. Will probably work, but likely load up like any other flapper. Get something actually made for paint. Just search paint stripping disc.
Thanks LD1.
   / A favor to your angle grinder #33
Yeah I am now a big fan of flapper discs and continue to stock up when I come across a good deal.
   / A favor to your angle grinder #34
Paint and rust, no problem, in my experience. You run into issues with any abrasive when you are trying to remove lots of millscale, as that is super hard stuff. Now if you are dealing with really heavy paint, you might want to abrade that away with a wire wheel first or it might clog up an abrasive disc, but I wouldn't worry about it for regular stuff.
   / A favor to your angle grinder #35
I will never use a wirewheel again after using them scotchbrite things.
No vibration, no flying wires, lots faster.
   / A favor to your angle grinder #37
I will never use a wirewheel again after using them scotchbrite things. No vibration, no flying wires, lots faster.
scotchbrite things"?? I'm curious, not sure what you are talking about?
   / A favor to your angle grinder #38
I'm thinking Rolocs.
   / A favor to your angle grinder #39
A link I posted earlier.
Here is a pic
   / A favor to your angle grinder #40
Good advice on the grinder grease. Never thought of it either and I have the same 18 volt grinder as the op. It also seams to be noisy now.
Will have to look into those scotchbrite things. I always used a braided wire wheel they don't seem to come apart as bad as the straight wire ones.
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR9EH765325 (A51572)
2014 International...
Landoll Hauloll (A52748)
Landoll Hauloll...
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
48" Skid Steer Pallet Forks  (A52384)
48" Skid Steer...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
