Additional weight for 6' rear blade
   / Additional weight for 6' rear blade #1
carrolle
fredericksburg,va.
John Deere 5205
Does anyone have any suggestions about how to add weight to my 6' Bush hog rear blade. Pics. would be much appreciated . Thanks Carroll
   / Additional weight for 6' rear blade #2
On my 6' rear blade in the spring I am going to mount railway track (the additional 160# should help it) to the concave side with hangers so it can be taken off for the winter.
   / Additional weight for 6' rear blade #3
I mounted an old concrete wheel weight in between the arch of the main frame of my 6.5 ft GB. Had it temporarily attached with a ratchet strap, till I found it was just what I needed to make it work. Then thru-bolted it to the frame after.
Shadow
   / Additional weight for 6' rear blade #5
A hydraulic top link would do the trick.
   / Additional weight for 6' rear blade #6
I just draped my loggin chains on the back blade frame for weight. The plus side is I have the chains ready for something'.
   / Additional weight for 6' rear blade #7
The hydraulic top link will make the rear blade a lot easier to use, but it won't add cutting force like additional weight will unless you have one of the odd tractors that has 3 point down force - most float when lowered.
   / Additional weight for 6' rear blade #8
If you are looking to get better cutting action you could try adjusting the top link to angle the blade edge away from vertical.
Sent from my iPhone using TractorByNet
   / Additional weight for 6' rear blade #9
Yeah I see now :)
   / Additional weight for 6' rear blade #10
Now why didn't I think of that. I'm gonna use that until I can get to the welding shop.
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2019 Toro Workman MDX Utility Cart (A51691)
2019 Toro Workman...
2012 Ford Escape XLS SUV (A51694)
2012 Ford Escape...
