Need Dust Caps for LandPride Grapple on a BX25D
   / Need Dust Caps for LandPride Grapple on a BX25D #1
Johnkn
Laplata, MD
Kubota LX3310
Greetings,
Have a new LandPride SGC05 grapple on a new BX25D. I need (2) male and (2) female dust caps to protect the Quick Connect hose ends when not using the grapple. I called LandPride, they weren't sure what size caps to use, but stated that the hose itself of 9/16" (presumably ID). The plastic caps would go over the 2 male and female QC ends. I would imagine something like this is common and even available on Ebay. Anyone have an idea of what size and where to get them? I would assume that the QCs for the 9/16" hose are likely all the same, maybe not. Right now I have a plastic baggie zip tied over the hose ends to keep them clean. :eek: thanks
   / Need Dust Caps for LandPride Grapple on a BX25D #2
Greetings,
Try Tractor Supply, I bought mine there. Your fittings should have a # on them. I'll guess 7241-1 A -or B
Perfect, I'll try them tomorrow, thanks....
   / Need Dust Caps for LandPride Grapple on a BX25D #4
The only ones I found at my local TSC were way too big. I think the 9/16ths may be the OD of the hose. I need these also for my LP grapple and hope someone can find a source. The Kubota dealer cost was outrageous to my recollection. It appears the ones on the loader QA hoses are the right size. I'll look tomorrow.
   / Need Dust Caps for LandPride Grapple on a BX25D #5
Well I did an Amazon search under "hydraulic fitting dust caps" and there are several to choose from. Also a Google search led me to Parker where I found this listing in their catalog.
   / Need Dust Caps for LandPride Grapple on a BX25D #6
Can you post a picture/and or the numbers on the couplers?
I have ones in stock that fit 1/4" and 1/2" ISO5675 "AG" type
   / Need Dust Caps for LandPride Grapple on a BX25D #7
My Kubota dealer included dust caps on my Land Pride grapple hydraulic couplers when they installed it.:D
Bill
   / Need Dust Caps for LandPride Grapple on a BX25D #8
Bill
No such luck here in central Texas. However, my dealer has recently been acquired by a multi location dealer and maybe positive things will result for the customer - at least one can hope.
   / Need Dust Caps for LandPride Grapple on a BX25D #9
View attachment 406214 View attachment 406215
KennyD - thanks for chiming in - always good to hear from the green side. I went out to my shop and here;s what I was able to read on the QA female connector. It says "SH25-14P 6000PSI MAX KV" The hose is 1/4 INCH - 4 (6.4mm) SAE100 R2 W.P. 5800 PSI. The bolt on hooks you have for the Kubota buckets look interesting.
   / Need Dust Caps for LandPride Grapple on a BX25D #10
I bet they are 1/4 fittings like my Ventrac.
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2012 INTERNATIONAL 4300 26 FT BOX TRUCK (A51219)
2012 INTERNATIONAL...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2017 Ford Fusion SE Sedan (A48082)
2017 Ford Fusion...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A51039)
2014 Yale 3 stage...
