Need Dust Caps for LandPride Grapple on a BX25D
   / Need Dust Caps for LandPride Grapple on a BX25D #1
Johnkn
Platinum Member
Laplata, MD
Kubota LX3310
Greetings,
Have a new LandPride SGC05 grapple on a new BX25D. I need (2) male and (2) female dust caps to protect the Quick Connect hose ends when not using the grapple. I called LandPride, they weren't sure what size caps to use, but stated that the hose itself of 9/16" (presumably ID). The plastic caps would go over the 2 male and female QC ends. I would imagine something like this is common and even available on Ebay. Anyone have an idea of what size and where to get them? I would assume that the QCs for the 9/16" hose are likely all the same, maybe not. Right now I have a plastic baggie zip tied over the hose ends to keep them clean. :eek: thanks
   / Need Dust Caps for LandPride Grapple on a BX25D #2
Greetings,
Try Tractor Supply, I bought mine there. Your fittings should have a # on them. I'll guess 7241-1 A -or B
Perfect, I'll try them tomorrow, thanks....
   / Need Dust Caps for LandPride Grapple on a BX25D #4
The only ones I found at my local TSC were way too big. I think the 9/16ths may be the OD of the hose. I need these also for my LP grapple and hope someone can find a source. The Kubota dealer cost was outrageous to my recollection. It appears the ones on the loader QA hoses are the right size. I'll look tomorrow.
   / Need Dust Caps for LandPride Grapple on a BX25D #5
Well I did an Amazon search under "hydraulic fitting dust caps" and there are several to choose from. Also a Google search led me to Parker where I found this listing in their catalog.
   / Need Dust Caps for LandPride Grapple on a BX25D #6
Can you post a picture/and or the numbers on the couplers?
I have ones in stock that fit 1/4" and 1/2" ISO5675 "AG" type
   / Need Dust Caps for LandPride Grapple on a BX25D #7
My Kubota dealer included dust caps on my Land Pride grapple hydraulic couplers when they installed it.:D
Bill
   / Need Dust Caps for LandPride Grapple on a BX25D #8
Bill
No such luck here in central Texas. However, my dealer has recently been acquired by a multi location dealer and maybe positive things will result for the customer - at least one can hope.
   / Need Dust Caps for LandPride Grapple on a BX25D #9
View attachment 406214 View attachment 406215
KennyD - thanks for chiming in - always good to hear from the green side. I went out to my shop and here;s what I was able to read on the QA female connector. It says "SH25-14P 6000PSI MAX KV" The hose is 1/4 INCH - 4 (6.4mm) SAE100 R2 W.P. 5800 PSI. The bolt on hooks you have for the Kubota buckets look interesting.
   / Need Dust Caps for LandPride Grapple on a BX25D #10
I bet they are 1/4 fittings like my Ventrac.
2017 Vermeer SC30TX Stump Grinder (A48837)
2017 Vermeer...
2005 FORD F-250 (A46684)
2005 FORD F-250...
2021 CATERPILLAR 303.5E2 CR EXCAVATOR (A50458)
2021 CATERPILLAR...
2015 Ford F-750 12FT Flatbed Truck (A46683)
2015 Ford F-750...
LOAD OUT AND SHIPPING (A48837)
LOAD OUT AND...
Commercial Dumpster (A49346)
Commercial...
