Kubota L4600 or Kubota L4701
   / Kubota L4600 or Kubota L4701 #11
The 4701 has a slightly nicer seat, new dash and steering wheel, and a lever for the throttle instead of a rotating arm. Plus all the Tier IV garbage on the engine (which likely offsets the HP benefit). If you can still find a new 4600, you should pee on the tires to mark it, wrap your arms around it, make a deal, and take it home ASAP. It's a no-brainer. If you're reading this you're already wasting time!!!!
   / Kubota L4600 or Kubota L4701 #12
I'd go with the L4600 over L4701.
The MX designation is a bit misleading as if you look at the specs it's really no more of a UT than the GL30 or GL40 which are CUTs; kind of a blurred line in this size. The MX has more features than the standard L Series and a really good buy though more expensive.
The MX as more weight out front and handles equipment better. It will easily out pull my L4300 even though the same engine. I think there is more frame up front on the MX and my hydraulic cylinders cycle faster so there must be better hydraulic flow. It might lift more with the 3 pt hitch because I can pick up things the L4300 won't.
It's either-or since both are really great tractors.
   / Kubota L4600 or Kubota L4701 #13
Yeah, it gets really fuzzy between the Grand L's, MX and M5140, just pulling up the spec sheets help see how close the GL, MX and M are all ahead of the standard L.
Of course it helps to go to the look and look at all of them. All are good tractors, but feel a bit different and with the spec sheets, time in person, you can hopefully get the right one for you; looks like we both did.
   / Kubota L4600 or Kubota L4701 #14
Every time a person inquires about info on a L-series tractor(s) it turns into a thread trying to convince the OP to buy a MX machine.
Interesting.
   / Kubota L4600 or Kubota L4701 #15
Interesting.
In my case the MX was cheaper than the l4600. That's why I said to consider it.
   / Kubota L4600 or Kubota L4701 #16
Interesting.
I went back and reread all the posts and only saw a couple mention "considering an MX, most simply recommended the L4600.
Interesting.
   / Kubota L4600 or Kubota L4701 #17
I understand, not directed at anyone in particular, just noticed in the past year Ive followed this site that is usually what happens. Not everyone wants a MX.
   / Kubota L4600 or Kubota L4701 #18
It could be worse, oftentimes someone will chime in with, you really need to look at a Kioti, LS, Mahindra etc.:)
   / Kubota L4600 or Kubota L4701 #19
Actually, whatever you are passionate about is the one that works.
(2) SPACE-RAY INFRARED HEATERS, INDUSTRIAL (A57192)
(2) SPACE-RAY...
(APPROX 125) UNUSED TRAFFIC CONES (A57193)
(APPROX 125)...
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
PAIR OF MINI RUBBER TRACKS (A57193)
PAIR OF MINI...
2014 Peterbilt 337 IMT 10,000LB 5 Ton Crane Mechanics Service Truck (A53422)
2014 Peterbilt 337...
2005 Kaufman Trailers Car Hauler Trailer (A53421)
2005 Kaufman...
