Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #691
Some of you guys mention selling logs on craigslist. I tried, oak and cherry, and only got guys who wanted me to GIVE it to them. I guess having it milled might be better, but I found very little market for logs. If you have lots of big trees, maybe you can get a logger in there.
   / Tractors and wood! Show your pics #692
Finally got to use my dump trailer I bought last summer
That's quite a trailer load of wood for your boiler. What are the dimensions and wt capacity?? Do you load that with your bucket??
   / Tractors and wood! Show your pics #693
Do you have any mills or log yards near by ? They would have a list of what they are buying and the specs on the logs they want.
   / Tractors and wood! Show your pics #694
Great looking set up! I have to say though, I don't understand the middle beam on the shed. It is not supported on the front side so what's the point? :confused3: Maybe you removed it for the picture? :D
If you look close you will see a large turnbuckle as the beam extends out the back. I needed an open front for loading logs. I turned the turnbuckle until I lifted the front beam about 1/2 inch. I don't know if it was necessary, but good eye for catching what looks like an anomoly.
Opps, looks like folks noticed the turnbuckle. It is a 20 foot opening. I will take a picture when it gets a good snow load and see if there is any deflection.
   / Tractors and wood! Show your pics #695
Good looking setup! How much for a sawmill like that? I love your sawmill shed.
Its a Canadian company but they have a wharehouse in the USA and ship all over the world. The Sawmill was less then 1/2 the price of any other bandsaw mill I could find at $2900. As well I bought an extension track so I can mill 16 foot logs. So with Mill, Extension tracks and 10 blades +taxes was about 4,000 cdn dollars. I did cut the main 20ft 6x8 beam but had to repossion the log to do that length.
   / Tractors and wood! Show your pics #696
Yeah did see the turnbuckle looking at it again but am hoping you have that well secured to the post and beam. A lot of load on the fasteners that are attaching it! Great looking set up!
   / Tractors and wood! Show your pics #697
The turnbuckle is fastened at each end with 4 - 1/4 inch x 3 inch long Lag bolts. The bolts won't pull out but the tie down ring might split so I will just beef it up when and if it does. Nice thing about having the mill is, no such things as 1 1/2 x 3 1/2 2x4s. They are real 2x4s, 6x6s etc. The structure and concrete pad are only 7 ft wide and the roof is 8ft.
   / Tractors and wood! Show your pics #698
Also of note, the funky bracing is fully customized so as to not hit me in the head, so if you are taller then 5ft 6, you better wear a hard hat.
   / Tractors and wood! Show your pics #699
Another angle of the Sawmill as well as my slowly growing lumber pile. One of the issues I run into is sorting the wood, ie if I need 2x4's I have to rearrange my piles. Left side is 9 ft pile and right side is lumber up to 14 ft long. I hope to build a 20x40 garage next summer. (Commercial trusses for roof)
   / Tractors and wood! Show your pics #700
It's a 1970s Winnabego grain trailer, GVWR is 18000, 3- 6000# axles, it's 7.5' wide and 16' long. The sides on it are 4' tall. I tossed the wood all in by hand as I split, but as sore as my arms are tonight I think the sides will get cut down a little shorter. It would have came originally with house trailer type axles, the previous owner put new axles and tires and replaced all the lights with LEDs. I added a battery as they had just used jumper cables from their truck battery. I have a wireless remote to add to it sometime also.
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
