Lots of flying embers will come off that pile and go hundreds of feet with the lightest of wind - a pile that size will create it's own. Those green cedar trees and dead weeds in the background burn quite easily. Our VFD does not issue burn permits. The decision to burn is the owners and so is all the responsibility. If they give you a permit will they be standing by while you burn?
In about 10 years it will be a mulch pile anyway.
Pics if you burn.
I have to agree with Don on this one; that's a fine pile but once it gets going the heat of the fire will naturally lift the embers and with wind they go a long long way.
JD, I even built a two foot high concrete block firepit, well my paid fireman helper did, a serious fire pit, and something hopped over it, and we looked up and fire had traveled really quickly over the top of the field grass for thirty feet.
I had a hose charged and ready and thank goodness for that. And this after previously hosing down the entire area.
But my point is crazy stuff happens particularly on windy days and chunks of stuff can get lifted and then smolder a long way off. Even though there is snow on the ground, which is good for sure locally, it makes putting out distant fires very hard. want to run through three hundred feet of snow to put out a tree on fire? and with what?
You actually need to be more careful in the winter if you are even remotely near other burnable stuff.
You aren't going to like to hear this but I think you should rent a
chipper from now on. Your area just isn't friendly to burning. At my last home I couldn't burn at all. Zero. Here in NC, Beaufort County, I was told NOT to call in a controlled burn ahead of time. Apparently folks don't start dialing 911 as soon as they see smoke here. Other than that, burn away, don't create a public nuisance I'm sure.
JD, I'm sorry the window is so short for you, hard to clean up that mess.
You know what, take some nice pastries down to the firehouse, remember, best defense is a good offense, and
play nicey nice and ask them if they want to do a fire training exercise on your pile, say when it's mostly burned down.
See if they bite...they may want something to burn and practice on. Never hurts to ask, but geez, as a past active volunteer fireman, I can sure tell you that yelling at volunteers is really a bad idea. You want to yell at municipal employees, go at it. Volunteers may be your friends who come to save your butt.
