Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #1
diesel lover
whites town indiana
Ferg. To 20, 1956 Massey F. MF 25 diesel, Ferg. 40, 1944 John D. A, 1965 cockshutt 40,
Well, Yesterday I was driving through my area and spotted a guy with a truck stuck in his own driveway. It was a newer Chevy 2500 Duramax diesel 2wd, with a gooseneck Dump Bed AND a New Holland Loader tractor inside the dump bed trailer. He had been trying to drive through his driveway and onto the road when he lost traction and slid sideways due to his rear wheels pulling him to the right of his driveway. We had been passing by when I noticed. His driveway was in the shade and had thick ice that froze, melted and refroze. I backed into his driveway and asked if he needed help. He replied with "was it that obvious?" I had grabbed my hitch and shackle and threw him my 20 foot 2 inch recovery strap.
My truck is a 2000 Gmc 1500 4wd with a 4.8 liter v8. Last winter I got stranded twice and needed assistance to get home. I had a 1997 Ford F150 with a 4.2 V6 and 2wd. Growing up in michigan I know everything about bad weather, but other drivers driving slow in front of me/ stopping randomly and causing me to loose all momentum had cause me to loose all traction last winter even with weight in my bed.
I had offered to help this guy because his trailer was so close to sliding into the trees on his driveway. When possible I help people in need because they have helped me when I needed help sort of a karma kind of deal.
If the option was available I would have hooked up two straps in the length of 30 to 35 feet +/- so I could have been on pavement and pulled him 10 times easier but with traffic coming quickly from the left side of the road it was far too dangerous. I tried to pull him with out a tug but it was not moveable at all. I backed up a small distance and gave it one planned tug and let the strap stretch, I applied the throttle and pulled it out of his spot. There was a car coming from the left so I had to back up off the road. When I did my strap came off the front hook of his truck. Had to rehook the strap and now had my front tires on the road, at this point I got a full pull out of it and pulled the truck, trailer and tractor onto the road! It was very stuck. He gave me a firm handshake and said he sure appreciated my help and Him and his wife had been talking about getting a 4wd truck to pull his tractor but hadn't yet.
A few things here, I don't push my vehicles more than they need to be. When using a stretching rope, or strap Its ALL about technique and not how much you can tear up your vehicle. I made sure to secure my end to a closed shackle and his was on the factory hook on the front of his truck. I gave one firm tug on his truck and did not give more throttle than needed. No need to damage anything of mine in the process. I am normally tugging on a more moveable object. Something that is either lighter or moves a small amount. When I gave the tug on his truck/ trailer combo It felt like the other end of my strap was hooked around a telephone pole! It had much less movement on it.
Surprisingly my half ton with a small V8 pulled out his heavy combination. Heres my estimates on the weight, 7/8000 pound chevy duramax, 3/4000 pound dump trailer and a 4/5000 pound trailer. My truck is a short bed single cab around 5000 pounds.
Last winter I worked for Old Dominion freight line as a truck mechanic and during the winter I plowed their lot using a WA 180 komatsu Pay loader. OD operates a large fleet of single drive axle trucks. Some of the worst are their single drive axle trucks pulling two pups (28 foot trailers). Single axle trucks are a nightmare when its -10 or -20 F with thick un removable Ice. OD did not purchase the proper recovery straps. If they had a 100,000 pound strap life would have been easier but we had to use chains. During which I had to pull out several stuck truck and trailer combinations, a pickup truck, and both of their highway plow trucks used to plow the 40 acre lot. One time a Chevy top kick was plowing the entrance to their lot last year and had slipped one set of duals into the ditch. Even with chains on the tires it was no match for the conditions. I had to remove the 20 foot box off the payloader, drive through the gate and precede with caution to pull him out. I had the 3/4 ton plow truck follow me to block off the road.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #2
how about some info on that strap you used?
Of course. Had it for six years now and its held up really well. Its made by Erickson Manufacturing. A 2 inch by 20 foot looped recovery strap and load ratings are 18,000 pound breaking strength and 9,000 pound maximum vehicle weight. Its worked really well and I purchased in at tractor supply in 2009. Now tractor supply sells the same thing as walmart. I would like to get a rope like 30 foot bubba rope at some point in time. They really have a softer stretch and stretch more than straps.
Erickson Manufacturing Ltd.
2
I would highly recommend these. They make up to a 10 inch wide 125,000 pound strap for heavier pulls. Lower quality straps do not stretch as much. The more stretch provided the safer it is on your vehicle and the more momentum can be built up.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #4
I have a strap that looks very much like that one, may be it in fact. Has worked well for random tree work pulling trees of houses, etc. I use it at the end of my logging rope to take the abuse. I have only pulled out a couple of people, but what I noticed is that in 4WD low with an auto transmission, you can really apply a lot of grunt getting people out when going slow and steady. I'd like to get a better rear hook or shackle for my truck though. Probably one of those drawbars with clevis for the trailer hitch would be best.
Anyone know if it's OK to pull someone in reverse? I thought I remembered hearing that this was potentially bad for the transmission.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #5
I also use a recovery strap but after having the back of my truck ran into twice because the drivers have their car floored and can't stop in time once their out. Now I have them apply the emergency break put it in neutral and get out then I pull them onto the rd.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #6
I have a strap that looks very much like that one, may be it in fact. Has worked well for random tree work pulling trees of houses, etc. I use it at the end of my logging rope to take the abuse. I have only pulled out a couple of people, but what I noticed is that in 4WD low with an auto transmission, you can really apply a lot of grunt getting people out when going slow and steady. I'd like to get a better rear hook or shackle for my truck though. Probably one of those drawbars with clevis for the trailer hitch would be best. Anyone know if it's OK to pull someone in reverse? I thought I remembered hearing that this was potentially bad for the transmission.
Pulling in reverse used to be the preferred way because your gearing was lower. Now with these modern 6 or more gear transmissions you more than likely have lower gearing in forward.
If towing in reverse I always use the passengers side tow hook just in case something gives way and comes through the windshield.
Chris
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #7
Around here we are pretty much known as the free wrecker service. No, we don't have a wrecker we pull with our trucks and sometimes the tractor(s) what ever it takes to get them out.
It always seems that we are pulling something or some one out of the mud. It's not uncommon to get a call in the middle of the night from friend(s). My son got a call at 3am last week to go pull and ambulance out of a guys yard.
I don't like pulling in reverse. I'm not worried about breaking anything (if it can be broke, I have done it) but you can't get a hard pull in reverse. I still do it on a lite pull, but if it's going to be a hard one, I had much rather pull forward.
The biggest part of pulling some one is getting the timing right. If they are asleep at the wheel it can make it much harder. If you are pulling dead weight, don't be afraid to tug on it some and remember to work your steering wheel back and forth. Let that dog hunt.
There's nothing wrong with a strap and I have used them, but I prefer a chain.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #8
Seems to me if you are pulling someone lower than you (like in a ditch) you would dig in better in reverse. Unless of course you have a lot of weight in the back of the truck.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #9
Rural King carries the Erickson straps. I've been thinking of buying one but haven't decided on a size. 20' or 30'? 2" or 3"? After reading this, I think the 30' would have more material to stretch. And I think 3" might be overkill for most jobs, and probably restrict some of the stretch on lighter pulls.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #10
Well, Yesterday I was driving through my area and spotted a guy with a truck stuck in his own driveway. It was a newer Chevy 2500 Duramax diesel 2wd, with a gooseneck Dump Bed AND a New Holland Loader tractor inside the dump bed trailer. He had been trying to drive through his driveway and onto the road when he lost traction and slid sideways due to his rear wheels pulling him to the right of his driveway. We had been passing by when I noticed. His driveway was in the shade and had thick ice that froze, melted and refroze. I backed into his driveway and asked if he needed help. He replied with "was it that obvious?" I had grabbed my hitch and shackle and threw him my 20 foot 2 inch recovery strap. My truck is a 2000 Gmc 1500 4wd with a 4.8 liter v8. Last winter I got stranded twice and needed assistance to get home. I had a 1997 Ford F150 with a 4.2 V6 and 2wd. Growing up in michigan I know everything about bad weather, but other drivers driving slow in front of me/ stopping randomly and causing me to loose all momentum had cause me to loose all traction last winter even with weight in my bed. I had offered to help this guy because his trailer was so close to sliding into the trees on his driveway. When possible I help people in need because they have helped me when I needed help sort of a karma kind of deal. If the option was available I would have hooked up two straps in the length of 30 to 35 feet +/- so I could have been on pavement and pulled him 10 times easier but with traffic coming quickly from the left side of the road it was far too dangerous. I tried to pull him with out a tug but it was not moveable at all. I backed up a small distance and gave it one planned tug and let the strap stretch, I applied the throttle and pulled it out of his spot. There was a car coming from the left so I had to back up off the road. When I did my strap came off the front hook of his truck. Had to rehook the strap and now had my front tires on the road, at this point I got a full pull out of it and pulled the truck, trailer and tractor onto the road! It was very stuck. He gave me a firm handshake and said he sure appreciated my help and Him and his wife had been talking about getting a 4wd truck to pull his tractor but hadn't yet. A few things here, I don't push my vehicles more than they need to be. When using a stretching rope, or strap Its ALL about technique and not how much you can tear up your vehicle. I made sure to secure my end to a closed shackle and his was on the factory hook on the front of his truck. I gave one firm tug on his truck and did not give more throttle than needed. No need to damage anything of mine in the process. I am normally tugging on a more moveable object. Something that is either lighter or moves a small amount. When I gave the tug on his truck/ trailer combo It felt like the other end of my strap was hooked around a telephone pole! It had much less movement on it. Surprisingly my half ton with a small V8 pulled out his heavy combination. Heres my estimates on the weight, 7/8000 pound chevy duramax, 3/4000 pound dump trailer and a 4/5000 pound trailer. My truck is a short bed single cab around 5000 pounds. Last winter I worked for Old Dominion freight line as a truck mechanic and during the winter I plowed their lot using a WA 180 komatsu Pay loader. OD operates a large fleet of single drive axle trucks. Some of the worst are their single drive axle trucks pulling two pups (28 foot trailers). Single axle trucks are a nightmare when its -10 or -20 F with thick un removable Ice. OD did not purchase the proper recovery straps. If they had a 100,000 pound strap life would have been easier but we had to use chains. During which I had to pull out several stuck truck and trailer combinations, a pickup truck, and both of their highway plow trucks used to plow the 40 acre lot. One time a Chevy top kick was plowing the entrance to their lot last year and had slipped one set of duals into the ditch. Even with chains on the tires it was no match for the conditions. I had to remove the 20 foot box off the payloader, drive through the gate and precede with caution to pull him out. I had the 3/4 ton plow truck follow me to block off the road.
That was nice of you to stop and help. When dealing with snow and ice it's only a matter of time till getting stuck and a friendly neighbor to stop and help is priceless. Snow and ice doesn't seem to care about truck brand or if you are late. I would say you have some good karma headed your way.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #11
Chris
Around here, pulling is reverse isnt about gearing, its about proper technique. Which I have had to show people a few times.
If trying to pull a car out of a ditch going forward, MANY times the car just likes to run the ditch and sometimes can slide/suck you into the ditch also.
By pulling in reverse, you can use your front tires to steer. Hook fairly short, maybe 10' chain/strap. And hook to the far side tow hook. As you are pulling, cut the wheels in the direction that will pull the vehicle out of the ditch.
Last winter, We had a ~10" or so event and I was sent out to do a lot that was missed. They had 3 semi's stuck. (no trailer). Back in between two buildings and drifted pretty bad. They were gonna call a tow service in but needed plowed to get back there. I was already out for more hours than I wanted and just wanted to get done. I backed up and handed the guy a chain. The look on his face was priceless. One of those "you got to be kidding me" looks. Truck had no problem pulling him out to where I had plowed a clean path (so he could get the rest of the way out). Did that to the other two trucks also. One of the hillbilly drives kept going on about cummins and how he knew it would do it blah blah blah. I told him the engine I had has nothing to do with it. ITs all about weight in the right place and traction. Was glad to get that day overwith:laughing:
Lighter pulls can be done in reverse, something that would not stress your vehicles. Sometimes reverse is better when you need to get someone out of a ditch quickly when its not going to be a tough pull.
If your going to be stressing your vehicle/ jerking and tuging do not do it. I knew a guy with a 90's Chevy pickup and he was pulling a dually 1 ton plow truck out of a spot. The blade was holding the plow truck even worse in the spot. They attached two or three straps and he was pulling and pulling in reverse. On the third jerk he cracked the case on his transmission, a 700r4. It immediately started to leak fluid and leave trails.
On the slow and steady comment, if I could have I would have pulled him from the road. His vehicle remaining stationary and mine gaining ground on the strap would cause building up of pressure on the strap. The constant pressure would have sucked him out of the spot as well. I like this method a lot when using two great anchor points on the vehicles. Unfortunately the years have changed, people like to drive way to fast and pay attention to the screen on their cell phone. I got him out the first time but had to back up from the road due to a car coming. This is when my strap came disconnected. When I pulled him the second time with my front tires on pavement it was a breeze!
If you can't decide the 30 foot works well in either 2 or 3 inch. If pulling with a 3/4 ton truck or 1 ton the 3 inch strap will work better and hold up better but does have less stretch. You can always double the line and have a 15 foot pull when there is limited room such as pulling a guy out of a ditch. Don't forget additional chain, shackles and other hardware as sometimes you need a chain to protect your strap from being torn by another vehicle.
GLAD you mentioned that. Im tired of cummins this, cummins that blah blah. The engine does not do anything. Its all in technique. Without proper technique you won't be getting far or damaging your equipment. When possible sometimes a 4wd loader tractor, backhoe, or wheeled loader can work better in some cases due to the weight and power of the machine. I have noticed sometimes a tractor or constrution equipment works better. I broke a ball joint on my 1/4 ton isuzu truck when I was in highschool. It broke on a super icy day and it was in the ditch. Tow company wanted $200 to tow my truck 1 mile to my home. My buddy called and said "were picking you up" they picked me up at my house, we hooked the front of my truck to a 3 point box grader on his 4wd tractor, and towed my truck to my home so I could replace the ball joint. A year later we had to do the same thing with his chevy mini van when a front wheel came off and he waited on the side of the road 2 HOURS for a wrecker.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #15
Yep, engine only comes into play when you have enough traction to run out of power. Very unlikely in winter conditions. Guy was just an idiot. 8000# of truck, 1000# of plow up front, and 2000# of concrete in the back is what was able to pull them out. Wasnt much load on the engine at all. I bet my 100HP saturn 4-cylinder would have made that pull if it was dropped in place of the cummins.:laughing:
Yes, that's no joke. Working as a truck mechanic I have used semi trucks to try to pull things before. The engine does not play as much into play as people like to think. If that were true semis without trailers would pull great but they don't. Using a 1984 international old highway plow truck I was able to pull a single drive axle sleeper truck hooked to two pup trailers when it was stuck. I am afraid that when I was pulling him even with salt in the bed my tires were spinning and spinning. I was pulling him slowly by surely when I heard my co worker start yelling at the driver "release your trailer brakes!" oooops he didnt even release his trailer brakes so I was dragging to axles across the ice.
Similar situations preformed with a Komatsu wa180 pay loader are a cake walk (when the driver releases the brakes!). I can have a 360 deg range of vision, and even with the lug tires they seem to get decent traction on the ice. Even with a much smaller 5.9 liter cummins there is plenty of power there. And I love the feeling of the powershift transmission as well. When you do get stuck with a wheeled loader like this that has center pin steering you can shift it side to side with the steering wheel and get it unstuck.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #17
Not a 700R4....
Chris
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #18
Have to be careful; good way to blow spiders.
Blew front spider in my old Jeep. When I had front diff rebuilt at ring/pinion shop, they said it was common. Reverse stress on gears.
Chris
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #19
When pulling in reverse , it tends to push the pinion gear away from the ring gear, the way the gears are designed. In foreword, it pulls the teeth into each other. That is why pulling forward is the preferred method.
   / Pulled out a guy yesturday, 3/4 Chevy 2wd, dump trailer, AND a NH loader tractor #20
Makes sense!
Thanks. Learned something new today.
Chris
2018 CATERPILLAR 289D SKID STEER (A60429)
2018 CATERPILLAR...
2015 KOMATSU WA270-7 WHEEL LOADER (A60429)
2015 KOMATSU...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
UNUSED FUTURE DHC 60" PALLET FORKS (A60432)
UNUSED FUTURE DHC...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
