Welding razor blades together, with a MIG
   / Welding razor blades together, with a MIG #11
I've never seen anyone weld razor blades together before but I have seen the welder at work win a $10 lunch bet for running a tig bead down the cutting edge of a razor blade. He did it on the 1st try without burning the blade or any pits.
James,,,,James,,,,James,,,, we wanna see YOU do it! :thumbsup:
But thanks for the links. Those blades are .012 thick, but he has a third blade doubling the bottom, so at the base it's .024", same thickness as the utility blades I welded above.
407615d1421768582-welding-razor-blades-together-mig-razor012-jpg
Very nice work.
Thats inspiring, I have to get a TIG setup - that would be pretty useful around here if I could ever get good at it. (pic from the youtube). Problem is I don't have enough projects like that to ever get the practice time in.
   / Welding razor blades together, with a MIG #14
   / Welding razor blades together, with a MIG #15
I use to have a picture from a friend who tig welded two sheets of aluminum foil together. He has it hanging up over his work bench. It was one of those things that he wanted to see if he could do it.
   / Welding razor blades together, with a MIG #17
Check out Plasma Welding on U-Tube. It's a cool process that would make razor blades simple to weld even setup as an outside corner. I've sold many plasma welding systems to the semi-conductor field that weld stainless steel foil with .5 amps under a microscope.. NASA has several systems doing Keyhole welding. Another interesting process. I like to see you guys trying this with mig. Not so easy.
"Kids - Do NOT try this with a MIG ! "
:laughing: :laughing:
   / Welding razor blades together, with a MIG #20
Enmark Z Spray (A53316)
Enmark Z Spray...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55314)
2020 New Holland...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A55314)
Mahindra 4550-4L...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
