Welding razor blades together, with a MIG
   / Welding razor blades together, with a MIG #11
I've never seen anyone weld razor blades together before but I have seen the welder at work win a $10 lunch bet for running a tig bead down the cutting edge of a razor blade. He did it on the 1st try without burning the blade or any pits.
James,,,,James,,,,James,,,, we wanna see YOU do it! :thumbsup:
But thanks for the links. Those blades are .012 thick, but he has a third blade doubling the bottom, so at the base it's .024", same thickness as the utility blades I welded above.
407615d1421768582-welding-razor-blades-together-mig-razor012-jpg
Very nice work.
Thats inspiring, I have to get a TIG setup - that would be pretty useful around here if I could ever get good at it. (pic from the youtube). Problem is I don't have enough projects like that to ever get the practice time in.
   / Welding razor blades together, with a MIG #14
   / Welding razor blades together, with a MIG #15
I use to have a picture from a friend who tig welded two sheets of aluminum foil together. He has it hanging up over his work bench. It was one of those things that he wanted to see if he could do it.
   / Welding razor blades together, with a MIG #17
Check out Plasma Welding on U-Tube. It's a cool process that would make razor blades simple to weld even setup as an outside corner. I've sold many plasma welding systems to the semi-conductor field that weld stainless steel foil with .5 amps under a microscope.. NASA has several systems doing Keyhole welding. Another interesting process. I like to see you guys trying this with mig. Not so easy.
"Kids - Do NOT try this with a MIG ! "
:laughing: :laughing:
   / Welding razor blades together, with a MIG #20
2015 Volvo VNL 64T (A55315)
2015 Volvo VNL 64T...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
Kubota L3130 (A53317)
2005 Kaufman Trailers Car Hauler Trailer (A55787)
2005 Kaufman...
kids dirt bike (A56859)
kids dirt bike...
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
