Cat. 1 implements with Cat. 2 quick hitch?
   / Cat. 1 implements with Cat. 2 quick hitch? #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
After hearing my friend rave about his I'm thinking about buying a quick hitch. The problem is that I have a mix of Cat. 1 and 2 implements. The one piece of equipment that I'm really focused on is my 24x20 (8') disc, which have standard Cat 1 pins. I've seen "conversion" pins, but they only seem to have a Cat. 2 pin diameter with a Cat. 1 threaded shand dia. but no increase in length.
Are there any problems or work-arounds to using a Cat 2 quick hitch with Cat. 1 implements?
Bushings - its easy and they are easy to find.
You don't have to change pins, you just put bushings on them and you are good to go.
But won't the Cat. 1 pin spacing still be too close together to work with the Cat. 2 quick hitch? With my old JD4020 (may he rest in peace) I had to adjust the width of the sway arms to go from Cat. 1 to 2 implements. It was a bit of a pain, but at least it was adjustable while the width of a quick hitch is fixed.
   / Cat. 1 implements with Cat. 2 quick hitch? #4
Yep, have to modify all the implements, or just get the ones that go on the lower arms.
Most of the tractors I'm looking at are listed as Cat. 2 only, so the Pat's style lower arms don't address my problem!
What are the modificiations? I've seen "conversion pins," but they only address pin diameter (just like a bushing), not the difference in width from Cat. 1 to 2.
   / Cat. 1 implements with Cat. 2 quick hitch? #6
It is different for every implement. You have to do something to get the spacing right. Usually requires cutting, welding, and fabbing something up.
   / Cat. 1 implements with Cat. 2 quick hitch? #7
Priefert and another company (ATI?) had a QH that was adjustable for the two sizes.
Bruce
   / Cat. 1 implements with Cat. 2 quick hitch? #8
   / Cat. 1 implements with Cat. 2 quick hitch? #9
Alot of times the Cat 2 listing only refers to the inside diameter of the lift arm "balls." Doesn't mean they will not hook to Cat 1.
You seem to have the different widths on your implements so if using a true quick hitch, would have to choose either the Cat 1 or 2 and modify the equipment accordingly. Otherwise, the Pats would solve the width problem, by being adjustable, and still give you the lower arm quick attach features.
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A55745)
2014 MAGNUM...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2012 Chevrolet Traverse LT SUV (A59231)
2012 Chevrolet...
flatbed trailer 24ft (A56857)
flatbed trailer...
UNUSED KJ 11' X 19' ALL - STEEL CARPORT (A52706)
UNUSED KJ 11' X...
2015 Bobcat S650 Skidsteer - Enclosed Cab - 5462 Hours (A56438)
2015 Bobcat S650...
