Cat. 1 implements with Cat. 2 quick hitch?
   / Cat. 1 implements with Cat. 2 quick hitch? #1
UncleBuck1
Baton Rouge, LA
2011 MF 2660HD; 1964 JD 4020 (may she rest in peace)
After hearing my friend rave about his I'm thinking about buying a quick hitch. The problem is that I have a mix of Cat. 1 and 2 implements. The one piece of equipment that I'm really focused on is my 24x20 (8') disc, which have standard Cat 1 pins. I've seen "conversion" pins, but they only seem to have a Cat. 2 pin diameter with a Cat. 1 threaded shand dia. but no increase in length.
Are there any problems or work-arounds to using a Cat 2 quick hitch with Cat. 1 implements?
Bushings - its easy and they are easy to find.
You don't have to change pins, you just put bushings on them and you are good to go.
But won't the Cat. 1 pin spacing still be too close together to work with the Cat. 2 quick hitch? With my old JD4020 (may he rest in peace) I had to adjust the width of the sway arms to go from Cat. 1 to 2 implements. It was a bit of a pain, but at least it was adjustable while the width of a quick hitch is fixed.
   / Cat. 1 implements with Cat. 2 quick hitch? #4
Yep, have to modify all the implements, or just get the ones that go on the lower arms.
Most of the tractors I'm looking at are listed as Cat. 2 only, so the Pat's style lower arms don't address my problem!
What are the modificiations? I've seen "conversion pins," but they only address pin diameter (just like a bushing), not the difference in width from Cat. 1 to 2.
   / Cat. 1 implements with Cat. 2 quick hitch? #6
It is different for every implement. You have to do something to get the spacing right. Usually requires cutting, welding, and fabbing something up.
   / Cat. 1 implements with Cat. 2 quick hitch? #7
Priefert and another company (ATI?) had a QH that was adjustable for the two sizes.
Bruce
   / Cat. 1 implements with Cat. 2 quick hitch? #8
   / Cat. 1 implements with Cat. 2 quick hitch? #9
Alot of times the Cat 2 listing only refers to the inside diameter of the lift arm "balls." Doesn't mean they will not hook to Cat 1.
You seem to have the different widths on your implements so if using a true quick hitch, would have to choose either the Cat 1 or 2 and modify the equipment accordingly. Otherwise, the Pats would solve the width problem, by being adjustable, and still give you the lower arm quick attach features.
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
Blue Diamond 103709 (A53317)
Blue Diamond...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A56438)
2023 Kubota...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2024 YANMAR TL100VS SKID STEER (A60429)
2024 YANMAR...
