How to gauge your trailer's tongue weight on an ongoing basis
   / How to gauge your trailer's tongue weight on an ongoing basis #11
I wonder if a pressure gauge could be fitted to a small hydraulic jack, then calibrated with test weights.
Bruce
Probably. But no ports usually. So would have to be dis-assembled and drilled somewhere for a tap.
   / How to gauge your trailer's tongue weight on an ongoing basis #12
To get an approximate idea you could try this. Lets say you want 600# on the tongue. Park on a level surface and measure the bumper height. Next find a couple friends that weight a total of 600# and have them stand on the bumper. Measure the drop in height. Hitch the trailer and compare the drop to what you had before.
PS: asking the wife to stand on the bumper is not recommended! :)
Tom
   / How to gauge your trailer's tongue weight on an ongoing basis #13
Tom
Yup. Put a known weight on the tailgate and measure the drop. 200, 400, 600, 800 etc...
   / How to gauge your trailer's tongue weight on an ongoing basis #15
Exactly. Did this with my last tow vehicle (SUV) and need to do it again with my new truck. It's not quite perfectly linear like an isolated spring would be, but it's very close. And of course there will be uncertainty if you have variable fuel weight, cargo weight, etc in the vehicle, but I found that it was possible to get a pretty accurate estimate as long as my vehicle was loaded more or less the same every time.
   / How to gauge your trailer's tongue weight on an ongoing basis #16
Greenboot - Tom - your post adds just what a thread needs when its getting overly serious/technical - some humor. Have a good day.
   / How to gauge your trailer's tongue weight on an ongoing basis #17
Well... in the spirit of adding uselessly technical confusion to the thread... :laughing:
You guys are just talking about static force, when the trailer is sitting still. I have always wondered what is the difference when we look at the trailer in motion. How much force does the tongue experience when you hit a bump or worse when you hit the brakes? I took a random picture from the internet and put some arrows on it. When you are driving the force on the tongue would be steady, but when you hit the brakes (red arrow) the slowing force from trailer and truck braking is very low to the ground relative to the center of the trailer load. This would mean the boat inertia which is located much higher up (black arrow) is going to continue forward and try to pivot over the axle, putting a lot of extra downward force (downward arrow) on the tongue. Isn't it? As well, when you add the forces on the truck the truck braking will drive the front of the truck down and the back of the truck upward (green arrows).
I am not an expert, but it seems to me that the higher the load weight and the load center of gravity, the more force you would experience in a downward direction from the trailer tongue and at the same time upwards from the back of the truck due to braking, dramatically increasing the "tongue weight" at that moment in time.
Anyone actually know anything about this? Am I wrong about how the force is applied?
   / How to gauge your trailer's tongue weight on an ongoing basis #18
   / How to gauge your trailer's tongue weight on an ongoing basis #19
If you are asking in regards to hitch strength, I think those forces are taken into consideration when they give the hitch ratings... much the same as a rope having a breaking strength rating and a "working" load limit.
2018 Ford F-450 Ext. Cab 4x4 Mason Dump Truck (A53422)
2018 Ford F-450...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
Cummins 6-Cylinder Diesel Engine with Transmission (A55852)
Cummins 6-Cylinder...
2016 Cat TL1055D Telehandler (A55314)
2016 Cat TL1055D...
202481 (A54757)
202481 (A54757)
SARLO MOWER (A55758)
