How many watts can the el cynical system handle?
   / How many watts can the el cynical system handle? #11
Your Org.# LB-4520 is only a 25/25w. With a dyno your maxed out at 180. I don't know your Elec. Sys. Gauges Etc. so keep that in mind and your have to add that in also. I can turn my dash off and if you are able to do that then wire the Lights in a separate Circuit.
15 amps X 12 volts = 180 watts.
Keep in mind that this is maximum output for this very puny little alternator. Alternators also produce less power when hot, and that 15 amp rating is at a high RPM, which is not stated.
   / How many watts can the el cynical system handle? #12
Carey - I emailed a couple of LED outfits to see if a LED equivalent of the 4550 is available...One response is in and they said no on e makes one ...yet.
   / How many watts can the el cynical system handle? #13
With the battery tender faithfully used. I would not hesitate to go 120watts of lighting.
   / How many watts can the el cynical system handle? #14
I've even seen an kept the old bulb and haven't seen anything like it. I don't ever use my lights maybe a Handful of times that I had to. And I do know that at a idle my Alternator puts out about 35amp @ 13.25v 463.75.watts Seems there would be a Conversion to a alt.. And if it there isn't I'd make one. with alittle Ingenuity. However you spell it!:D And that dynamo would be gone.
   / How many watts can the el cynical system handle? #15
Alternator or Generator does not matter. You take the amperage (I) output multiply by 12 (V) and get the power output (W)
Power = I x V (also can use E for voltage) which give you PIE P=IE
So if you have a 198 amp alternator 198 (I) x 12 (V) = 2376 Watts.
Hope this helps.
EM1(SS) Retired
   / How many watts can the el cynical system handle? #16
Carey your alternator is 198 amps!!!! that seems huge!
Is it simple to measure how many amps the dynamo can give? I have a digital multimeter. If it is I could check mine at idle and other speeds, then I d know for sure.
   / How many watts can the el cynical system handle? #18
Just a little :ashamed: Watts
   / How many watts can the el cynical system handle? #20
One of the forum sponsors does have LED lights for our tractors ...
http://www.tractorbynet.com/forums/owning-operating/232466-led-xenon-work-lights-your.html
Maybe these are drop in for the YM series. Maybe we just ask for the measurements.
Peterson LED Headlights
The Peterson's are made in the USA. They make headlamps for the older motorcycle and ATV stuff in LED. With that said, the Yanmar headlamps often used the motorcycle square headlamps.
Vehicle Safety Light| LED Lights - Peterson Manufacturing Company 702/703 - 4"x6" Rectangular LED Headlights
2020 ISUZU NQR (A55745)
2020 ISUZU NQR...
2005 INTERNATIONAL 9400I DAYCAB (A55745)
2005 INTERNATIONAL...
2012 Dodge Grand Caravan SXT Van (A55853)
2012 Dodge Grand...
EZ-GO Cart (A55853)
EZ-GO Cart (A55853)
2015 COACHMEN CATALINA CAMPER (A55745)
2015 COACHMEN...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
