How many watts can the el cynical system handle?
   / How many watts can the el cynical system handle? #21
Is it simple to measure how many amps the dynamo can give? I have a digital multimeter. If it is I could check mine at idle and other speeds, then I d know for sure.
You can measure the output using a DC ammeter. But that would only show you what it it putting out. There should be a data plate on it.
   / How many watts can the el cynical system handle? #22
I just replaced the dynamo (5 amps, 60 watts at 2500 rpm) on my K7100 with a 20 amp, 240 watt, Kubota alternator. It was necessary to run the electric air fan on my cab heater retrofit. I also run 3 -3amp bulbs, 2 wipers, a strobe and a dome light plus an electric coolant pump easily with that alternator. I had to fab up a set of brackets for the alternator mounting and modify the hood as well as re-config the exhaust to vertical vice the horizontal position to fit it in. My battery always shows a full charge now. it was a lot to do, but not difficult, except for loosening the seized manifold bolts, That took a OA torch and some repeated hot-cold cycles to get the bolts out without breaking them. It can be done. LEDs do use less power, but my loads were still outside the capacity of the dynamo, so I had no choice but to reconfig the electric system. It works fine now.:tractor::dance1:
Jix
2022 Takeuchi TL12R2 (A55272)
2022 Takeuchi...
Pallet of 10 Chains and 5 Binders (A57454)
Pallet of 10...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
PALLET OF MISC ELECTRICAL WALL BOXES & MISC CAPS (A58376)
PALLET OF MISC...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58216)
2008 TCE...
