careyo63
Elite Member
- Joined
- Jan 6, 2012
- Messages
- 2,701
- Tractor
- 77 Yanmar YM2000 63 Ford 2000
Your Org.# LB-4520 is only a 25/25w. With a dyno your maxed out at 180. I don't know your Elec. Sys. Gauges Etc. so keep that in mind and your have to add that in also. I can turn my dash off and if you are able to do that then wire the Lights in a separate Circuit.
15 amps X 12 volts = 180 watts.
Keep in mind that this is maximum output for this very puny little alternator. Alternators also produce less power when hot, and that 15 amp rating is at a high RPM, which is not stated.
