Brush hog where poison ivy is???
   / Brush hog where poison ivy is??? #11
I mow it every time I see it. Set the bush hog low and just go at it. Never had a problem with getting it from mowing, hopefully I never will.
   / Brush hog where poison ivy is??? #12
Hit it with Roundup when the weather is warm(the hotter the better). I sprayed it and 3 days later it was gone, not wilted but gone.
Charlie
   / Brush hog where poison ivy is??? #13
I would just rinse of the mower and tractor with some soap and water after you cut through it. I get it somewhat mildly and I got some on my arms after working on my cutter last summer. Also if its where you travel frequently I would spray it to control it.
   / Brush hog where poison ivy is??? #14
I get it just thinking about it, but I mow it all the summer long. It's a never ending battle and very personal.
About 6 years ago I read that if you wipe yourself down with rubbing alcohol after you are exposed it will neutralize/remove the oil. So far so good, I have not had a bad case since I started doing that. Just do it with a half hour of exposure. I carry alcohol wipes with me at all times. You can also spray or wipe down your equipment with it.
   / Brush hog where poison ivy is??? #15
I am highly allergic (think permanent scars, visits to the hospital). Repeated mowing will kill it (no it doesn't spread by being cut up). I've never had any issue, just wear long clothing and wash everything after. Technu works good to get it off. It shouldn't aerosolize just with mowing. Mow before it gets berries in the falls that is how it spreads (via birds)
   / Brush hog where poison ivy is??? #16
Brush b gone by Ortho kills it.
   / Brush hog where poison ivy is??? #17
Mowing it will make it spread to beat heck. Poison it with a sterilant herbicide. Javex works good in 50-50 water mix too and will degrade to non toxic state in short order in sunshine Be sure to wet the plant and the roots with it thourougly. In a week, it will all be bead, but still poisonous. Do Not burn it and then stand in the smoke.
   / Brush hog where poison ivy is??? #18
I've mowed, sprayed and uprooted in no particular order my fair share of poison ivy over the years and never had a problem. My poison ivy radar is always on, unless I've touched it or touched a pet who's been into it I don't have a problem. However, when I get it, I get it!
   / Brush hog where poison ivy is??? #19
Get goats. They eat it, no problem.
   / Brush hog where poison ivy is??? #20
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
Misc Office Supplies/ Accessories (A50325)
Misc Office...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2022 PETERBILT 389 MID-ROOF SLEEPER (A52472)
2022 PETERBILT 389...
2022 New Holland Powerstar 90 Tractor with Loader (A51573)
2022 New Holland...
