Snow Sticking Inside Bucket - Silicone Spray or Something Else?
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #1
MarkF48
Gold Member
Massachusetts
Mahindra 2216
Moved a bunch of snow today and the snow tended to stick inside the bucket in fairly large clumps when I dumped it so I wasn't getting a full buckets worth on the next pickup. I've tried silicone spray and it works well for a while, but seems to not last long and isn't exactly a cheap way for the size of the bucket. I'm thinking of waxing the inside of the bucket if we get a reasonably warm day to see how that works and holds up.
What are you using if anything?
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #2
Spray it with some diesel fuel
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #3
Wax may work well. Something like wd-40 or fluid film would probably work as well, but probably wouldn't last any longer than your silicon spray.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #4
nothing will work for very long. It's a waste of time and money. Been there, done that.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #5
I use spray wax, that's right I wax the inside of my bucket ! truth be told, it does work well, but doesn't last long. Maybe 2 storms. It's more fuel for friends to bust my chops.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #6
Fluid film. Fleet Farm and O'Reilly just started carrying it. I bought some because of how everyone on here raves about it. They're right. It's awesome. And it's non-toxic. I'll be ordering a case this week.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #7
I'm with ya Pilgrim. I run a Road Grader. I've tried everything, including pouring water on the Plow to create a layer of ice that the snow would slide off of. Yeah right....
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410953"/>
Looks like your layer of ice is too thick :)
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #9
I think Richard you could have gotten the same results with molasses.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #10
What can work, depending on the surface and means of application, is a plastic facing or lining.
HDPE* is one form of plastic that is fairly resistant and can be heat moulded.
Some plows use it as a moldboard, I once lined the blower chute and it worked just fine.
*High density polyetheline.
2025 25ft 1 Gauge 800 Amp Booster Cables (A50323)
2025 25ft 1 Gauge...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
2015 Ford Econoline Van, VIN # 1FDWE3FL4FDA28220 (A51572)
2015 Ford...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 Ford F-150 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
