Snow Sticking Inside Bucket - Silicone Spray or Something Else?
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #1
MarkF48
Gold Member
Massachusetts
Mahindra 2216
Moved a bunch of snow today and the snow tended to stick inside the bucket in fairly large clumps when I dumped it so I wasn't getting a full buckets worth on the next pickup. I've tried silicone spray and it works well for a while, but seems to not last long and isn't exactly a cheap way for the size of the bucket. I'm thinking of waxing the inside of the bucket if we get a reasonably warm day to see how that works and holds up.
What are you using if anything?
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #2
Spray it with some diesel fuel
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #3
Wax may work well. Something like wd-40 or fluid film would probably work as well, but probably wouldn't last any longer than your silicon spray.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #4
nothing will work for very long. It's a waste of time and money. Been there, done that.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #5
I use spray wax, that's right I wax the inside of my bucket ! truth be told, it does work well, but doesn't last long. Maybe 2 storms. It's more fuel for friends to bust my chops.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #6
Fluid film. Fleet Farm and O'Reilly just started carrying it. I bought some because of how everyone on here raves about it. They're right. It's awesome. And it's non-toxic. I'll be ordering a case this week.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #7
I'm with ya Pilgrim. I run a Road Grader. I've tried everything, including pouring water on the Plow to create a layer of ice that the snow would slide off of. Yeah right....
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #8
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=410953"/>
Looks like your layer of ice is too thick :)
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #9
I think Richard you could have gotten the same results with molasses.
   / Snow Sticking Inside Bucket - Silicone Spray or Something Else? #10
What can work, depending on the surface and means of application, is a plastic facing or lining.
HDPE* is one form of plastic that is fairly resistant and can be heat moulded.
Some plows use it as a moldboard, I once lined the blower chute and it worked just fine.
*High density polyetheline.
KUBOTA ZD1211 (A53084)
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
