Country Mfg 2 Ton Wagon
   / Country Mfg 2 Ton Wagon #2
You should be able to find a cylinder at any farm supply store. Amazon sells them too.
If you're not an expert at backing wagons with the steering tongue I definitely recommend getting a trailer. They are much more maneuverable.
   / Country Mfg 2 Ton Wagon #3
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder I got that from Bailey. There was a good amount of hydraulic line to tie it all together too. A local Parker dealer had all the fittings I needed and made up the hoses. Ran it off the valve I had plumbed in for my hydraulic toplink.
It was handy. Flexed a bit with good load on it but nothing ever broke. Did wish it had a different wheel bearing/hub assembly but as they say "not for over the highway use" :D
   / Country Mfg 2 Ton Wagon #4
I own the trailer/dump cart version (not a wagon with it's own steering) and I fully agree with the following:
   / Country Mfg 2 Ton Wagon #5
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder ...
It was handy. Flexed a bit with good load on it but nothing ever broke. ...
I've used a 4 x 24 on mine ... like you say, they are prone to flexing if you load them up.
I've never personally broke anything on mine - and I've hauled a lot with it - but a friend I loaned it to managed to break the hinge mount ... probably by overloading it ... :mad:
It's a handy little unit if you have property and need to haul stuff around.
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
UNUSED FUTURE VR59 59" VIBRATORY ROLLER (A51248)
UNUSED FUTURE VR59...
40' CONTAINER (A51248)
2013 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A52377)
2013 Chevrolet...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
