Country Mfg 2 Ton Wagon
   / Country Mfg 2 Ton Wagon #2
You should be able to find a cylinder at any farm supply store. Amazon sells them too.
If you're not an expert at backing wagons with the steering tongue I definitely recommend getting a trailer. They are much more maneuverable.
   / Country Mfg 2 Ton Wagon #3
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder I got that from Bailey. There was a good amount of hydraulic line to tie it all together too. A local Parker dealer had all the fittings I needed and made up the hoses. Ran it off the valve I had plumbed in for my hydraulic toplink.
It was handy. Flexed a bit with good load on it but nothing ever broke. Did wish it had a different wheel bearing/hub assembly but as they say "not for over the highway use" :D
   / Country Mfg 2 Ton Wagon #4
I own the trailer/dump cart version (not a wagon with it's own steering) and I fully agree with the following:
   / Country Mfg 2 Ton Wagon #5
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder ...
It was handy. Flexed a bit with good load on it but nothing ever broke. ...
I've used a 4 x 24 on mine ... like you say, they are prone to flexing if you load them up.
I've never personally broke anything on mine - and I've hauled a lot with it - but a friend I loaned it to managed to break the hinge mount ... probably by overloading it ... :mad:
It's a handy little unit if you have property and need to haul stuff around.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2006 HAMM HD120HV SMOOTH DOUBLE DRUM ROLLER (A51246)
2006 HAMM HD120HV...
EZ GO EXPRESS S4 EFI GAS GOLFCART (A51247)
EZ GO EXPRESS S4...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A53472)
2018 Link-Belt LBX...
