Country Mfg 2 Ton Wagon
   / Country Mfg 2 Ton Wagon #2
You should be able to find a cylinder at any farm supply store. Amazon sells them too.
If you're not an expert at backing wagons with the steering tongue I definitely recommend getting a trailer. They are much more maneuverable.
   / Country Mfg 2 Ton Wagon #3
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder I got that from Bailey. There was a good amount of hydraulic line to tie it all together too. A local Parker dealer had all the fittings I needed and made up the hoses. Ran it off the valve I had plumbed in for my hydraulic toplink.
It was handy. Flexed a bit with good load on it but nothing ever broke. Did wish it had a different wheel bearing/hub assembly but as they say "not for over the highway use" :D
   / Country Mfg 2 Ton Wagon #4
I own the trailer/dump cart version (not a wagon with it's own steering) and I fully agree with the following:
   / Country Mfg 2 Ton Wagon #5
I had the 8500 several years back. If I remember right I used 3.5X24 cylinder ...
It was handy. Flexed a bit with good load on it but nothing ever broke. ...
I've used a 4 x 24 on mine ... like you say, they are prone to flexing if you load them up.
I've never personally broke anything on mine - and I've hauled a lot with it - but a friend I loaned it to managed to break the hinge mount ... probably by overloading it ... :mad:
It's a handy little unit if you have property and need to haul stuff around.
UNIVERSAL WOLVERINE PFF2-13-45W QUICK ATTACH MAST (A51248)
UNIVERSAL...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
Ford Tractor (A50120)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
Ford Super Duty 8ft. Truck Bed (A51692)
Ford Super Duty...
2003 HONDA RANCHER 350 ATV (A51247)
2003 HONDA RANCHER...
