I broke my three point hitch.!!!
   / I broke my three point hitch.!!!
You could always put power service 911 in your filter and screw n it on and same with the tank and it would do the same as kerosene and maybe faster.
I've tried both white and red and they have never worked for me by themselves. The kerosene is $1.50 a gallon more then diesel so for the price of a bottle of 911 I can have four gallons of kerosene and treat twenty gallons of diesel.
   / I broke my three point hitch.!!! #52
Hey VTSNOWEDIN living in NC I don't have the fuel gelling problem. What exactly do you do with the kerosene?
Thanks
Thanks
Just add it to the fuel tank looking for a 30-70 mix with the diesel. The kerosene is thinner and won't jell up. People that live in old trailers here use kerosene in the furnaces as the tank sits outside and #2 diesel will jell up on cold nights when you need it most. It is -10 F here as I write this heading for 20 below by dawn.
   / I broke my three point hitch.!!! #54
I live in warmer country now but i am from Nebraska. We have cut the diesel with a little gas if we didn't have any kerosene. I think kerosene is the way to go but gas will work in a emergency.
I've heard of that but wouldn't know the right amount to mix in and I bet no manufacturer will stick their neck out and clue us in. As you say would be an emergency situation only.
I do remember a guy putting something like three gallons of gas in with twenty gallons of diesel into a Mercedes back in the early seventy's but that memory is old and fuzzy.
   / I broke my three point hitch.!!! #56
I remember one time a rancher had us build a small fire under the tractor to get it warm enough to get it running. And yes i know that sounds crazy!
Yup crazy!! But My father would take the ash pan from the kitchen stove and fill it with red hot coals and slide it under the oil pan of the family car. Taking care to not pump the gas or try to start it first to keep any gas off the engine block. In a couple of minutes you could hear the moisture in the bottom of the oil pan begin to crackel and pop. Slide the ash pan out of the way with a garden hoe and give her a whirl. Another thing was to take a quart can of oil (it used to come in metal cans) open it and heat it to boiling hot before dumping it into the engine.
   / I broke my three point hitch.!!! #58
That's funny! I've heard of those "old" technological approaches except the boiling a quart of oil... Whoa.. I think I'd stay outta the kitchen for that!
AKfish
AKfish
Yup had to be careful to not have it expand and run over the top and onto the wood stove lids. Have good gloves on or a stove mitt ready and carry it out to the car real careful.
   / I broke my three point hitch.!!! #60
Don't try to heat a full can of oil. Remove some first to avoid spills.
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
2004 Ford F-550 Miller 301 Wrecker Truck (A55852)
2004 Ford F-550...
New Wolverine Sid Steer 3PT Hitch Quick Connect (A59000)
New Wolverine Sid...
2014 RAM 2500 (A58214)
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
TEST YOUR BID BUTTON! (A52708)
TEST YOUR BID...
