Good morning!!!!
   / Good morning!!!! #30,691
Man Larro, That looks good!!
   / Good morning!!!! #30,692
Yeaaa!!!!! The crowd went crazy when the ice flow went away. Water, water, Thank the Lord we gots Water!!!!!!
Glad to hear you got water! We have not had much for winter in the last two years. I haven't even used my snowblower for two years. It was like 55° today, we should have snow on the ground but we don't.
   / Good morning!!!! #30,693
Why did the chicken cross the road? To show......
If you guys will post a picture to another website, then copy the image URL and paste it here, you will be able to post pictures. Very big pictures.
Larro
36˚ windy, cold, winters back. The WBS is cranking out the heat.
Another Website? Isn't that's like cheating on TBN? - I WON'T DO IT! I wait patiently till they find the fix.
   / Good morning!!!!
Larro
I am hungry, for some reason....:)
   / Good morning!!!! #30,695
1F @ 02:00 ... kinda chilly out there ...
Just came down from the shop. Looks like it was in the nick of time ... temp in the house is currently 59F ... and the only thing left in the wood furnace was a huge bed of coals. Loaded it up and got it hummin' ...
Like someone else said: It's eatin' wood like it was candy.
Earlier today it appeared that the small Dayton blower on the wood furnace had failed. I tried bypassing thermostatic switch that controls it and nada ...
Then I pulled it off and took it upstairs as I was going to take it up to the shop and replace the motor with a spare I have. Decided to plug it into an outlet and it spun up. Took it back downstairs and reinstalled it and wired it up ... nada ...
It was The 'Cake that finally made the call: What about the circuit breaker ?
Doh ...
Earlier in the day I had tried to fire up the air compressor in the garage to pump up a low tire ... it stalled ... and apparently tripped the breaker.
The 'Cake earned bonus points today.
   / Good morning!!!! #30,696
RS -
I hope you are documenting all these little forest fires you have to put out. It seems every time you go to do something you have to fix something else first. Why did the compressor trip the breaker?
   / Good morning!!!! #30,697
Cats are very much individuals ...
With the one cat it's THE HAND - she can never get enough. With her brother, it's THE LAP ... especially if said LAP is in close proximity to a heating appliance.
Try to load or otherwise tend the wood furnace and it's like he has radar ... he could be stone-cold sound asleep at the other end of the house and if the door to the furnace is opened he'll be there inside of 60 seconds ... usually meowing if the lap is not made immediately available.
If any petting occurs while in this state of toasted comfort, the certain result is massive amounts of drool. You'd think he'd died and gone to Cat Heaven.
Judging from the strings of slobber, apparently I have a St. Bernard type of cat ...
   / Good morning!!!! #30,698
RS -
Isn't that what I just did ... document it ?
:D
Perhaps that's because I often write about Life's little travails (aka adventures) ... ;)
I'm guessin' because that compressor is in the (unheated) garage ... and it's only a couple of degrees F out ...
But it could be because it's 30+ years old ... and it was just it's time ...
   / Good morning!!!! #30,699
2015-02-17, 0321
-13 right now...Brrrrr! Today's high will be about 22.
   / Good morning!!!! #30,700
Now that's an example of a dominant wet *****!
New/Unused Gold Mountain 12ft x 20ft Steel Carport (A57454)
New/Unused Gold...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
2003 Hummer H2 4x4 SUV (A56859)
2003 Hummer H2 4x4...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
2020 DRAGON ESP...
