New Member -YM 1700 transmission dipstick length
   / New Member -YM 1700 transmission dipstick length #1
tgrammar
Nashville, TN
Yanmar YM1700
Hi all,
Bought a 1700 a couple months ago as my first tractor and have enjoyed getting to know it.
My transmission dipstick is missing and i'm wondering if someone with a 1700 could measure the dipstick and respond with specs i could then use to glue a rod into the cap i have
unless there's some reason i absolutely should buy a used one from hoye for around $30
i suppose theres a chance the dipstick is down in there somewhere, so im planning on fishing around with a retrieving magnet first...
ive had a slight issue with the hydraulic system so it would be nice if i could at least check the level
thanks in advance!
   / New Member -YM 1700 transmission dipstick length #2
I believe there were two styles of caps. One with, one without dipstick.
Dave
   / New Member -YM 1700 transmission dipstick length #3
:welcome:
To TBN from Alabama. If yours is without the dipstick, then I would think that getting one with a dipstick would be very easy.
   / New Member -YM 1700 transmission dipstick length #4
Welcome to the forum. :welcome:
Part #194150-24290 is 33mm x 184 long. Translates to 7.24409". I measured my 2002D dip stick 194190-24290, 33mm x 157, 6.1811". The 157 measurement on my dip stick is taken from the very bottom of the plastic screw in part to the very end of the dip stick. Starting at the very bottom of the dip stick and coming up about 11/16" is cross hatched and indicates approved level. Hopefully someone will measure the 1700 dip stick for you so there will be no question.
   / New Member -YM 1700 transmission dipstick length #5
The 1700 and the 2000 use the same DS. This is my Ym2000. If you remove the Rubber Washer It's 8". Or 23 cm.
   / New Member -YM 1700 transmission dipstick length #6
Guessing it is also 184mm from the bottom of the thread area. Everyone probably already knows this but the level is to be checked with the dipstick resting on the threads and not screwed in.
   / New Member -YM 1700 transmission dipstick length #7
Could be that's why I measured it in CM. also. I'm not good for anything much over 21 using my pointer. I run out of Fingers and Toes you know. :D
   / New Member -YM 1700 transmission dipstick length #8
Looks like the one on my 276D. Don't know if the length is the same.
   / New Member -YM 1700 transmission dipstick length #9
Welcome from Wisconsin
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
LMC G500-500A LOT NUMBER 233 (A53084)
LMC G500-500A LOT...
2019 FORD F-550(INOPERABLE (A52472)
2019 FORD...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
