Keeping shaft bearing supports true...
   / Keeping shaft bearing supports true... #1
/pine
Super Star Member
This week I am going to be fabricating a short (8") jack shaft mounted on a piece of 1/4"x 3" plate...
The two brackets that hold the (flange) bearings will be welded to the plate...I'm sure I can get everything tack welded together but I'm concerned that when I fully weld the brackets there could be some distortion...first on one end then possibly the other...
Any advice or tips to keep the alignment true when I do the welding?...Should I weld short sections alternating between ends?
The brackets are 3/16"...I'm thinking using the 1/4" plate will help some?
I hate to leave the bearings/shaft in while I'm doing the final welding...on one bracket a weld will only be 1/2" from the bearing race...!
   / Keeping shaft bearing supports true... #2
I would not weld the flanges. Bolt the bearing flanges to welded brackets. This will allow the bearings and flanges to find their true axis. Or line bore the flanges after welding.
   / Keeping shaft bearing supports true... #3
Standard flange mount bearings swivel in the mounting flange and will find their alignment.
As long as you have things lined up you should be able to tack it together then weld with the bearings removed.
Skip welding does help with distortion.
Thanks...I was hoping to keep it as simple as possible and keep the fabrication to a minimum...
Once I get to the actual (arbitrary) design work and see exactly how much room there is...I will re-evaluate and if there is room I will weld some vertical pieces with slot holes to bolt the bearing brackets to...
The use of spherical bearings eliminate your concern. Cheap, common as dirt.
Do they come with a flange? the bearings I have...have a flange that keeps them from passing through the hole in the bracket...??
   / Keeping shaft bearing supports true... #6
You could also use pillow block bearings that would bolt directly to the plate. No welding. They also are spherical and self-aligning.
That is the way I was originally going to go...but one of the pillow blocks would take up too much room and complicate making the shroud...
   / Keeping shaft bearing supports true... #8
I think there is some confusion as to the type of bearings you are using. Typically, flange bearings are a spherical bearing that swivels in a 2 bolt or 4 bolt flange. I get the impression you are referring to a regular roller bearing with perhaps something like a snap-ring around the outer race?
Yes...I erred in referring to the bearings I have...they are just typical roller bearings where the outer race has a flange...the bearings slip into a bored hole in the 3/16 brackets...the flange holds it in place...
   / Keeping shaft bearing supports true... #10
Is the shaft turning fast? If so I would find a way to use mounted self aligning bearings that bolt on. If the shaft turns slow or not at all (like a crank arm for instance) then you could put a stiff Grade 8 or 9 bolt of the correct diameter in the bearings to keep things lined up (more or less) while you weld.
CASE TV370B SKID STEER (A52706)
CASE TV370B SKID...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
CHALLENGER MT525B TRACTOR (A59823)
CHALLENGER MT525B...
Unused 2025 CFG Industrial MH12RX Mini Excavator (A59228)
Unused 2025 CFG...
Wolverine Quick Attach Screening Bucket (A59814)
Wolverine Quick...
