Care to guess on a truck problem?
   / Care to guess on a truck problem? #41
Good stuff :thumbsup: .
If your buddy is planning on keeping the truck around, suggest he coat the terminals he cleaned to seal out corrosion, if he didn't already.
There are a few discussion threads on here about what to use.
A couple of suggestions:
Permatex Dielectric grease
Electrical System Maintenance : Permatex
Even Fluid Film would be better than nothing.
Matters the most up here in Winter salt country. But, connections can/do corrode everywhere, and esp. near a coastal shoreline.
Rgds, D.
   / Care to guess on a truck problem? #42
A lady that works in the same building had the hood up late last Friday night... her Dodge wouldn't start because it was stuck in park...
She was getting panicked because she was late picking up her kids and her husband works swing so there was no one to call...
I went back inside to my office and did a Internet search and sure enough there was a work around and was able to get her going...
I really love forums and the Internet for problem solving!!!
   / Care to guess on a truck problem? #43
Life is even better when you whip your android smart phone out of your pocket, Swipe up and say OK Google! into it.
Or you can invoke that Siri lady if you are apple inclined!:)
You would be surprised the kind of problems that a good "OK google" can solve:)
You know just thinking about the neighbors truck, its hard for me to believe that a 2003 80k mile babied truck had some wire that wasnt making good contact because of corrosion. I mean we live in an area that doesnt use salt on the roads and generally speaking things dont just corrode like that around here, least Ive never heard of it. Its a typical case of "I learn something everyday."
Just wish he would have been able to isolate which exact connection or connects it was.
   / Care to guess on a truck problem? #45
You are way better off than us in the frozen North. All electrical connections up here need to be coated.
However, heat+humidity are factors for corrosion, so you don't totally get a free pass.
It doesn't take much to get corrosion started - one trip to a salt-water boat launch will do it, or even just parking near the ocean for a while.
Rgds, D.
   / Care to guess on a truck problem? #46
I have a 2004 Dodge 3/4 ton and had a similar problem. It started and ran fine but was starting to have some random electrical glitches. I also just cleaned a lot of contact and it fixed it. Age often affects that stuff more than the mileage.
   / Care to guess on a truck problem? #47
Dodge was notorious for a 'no start' situation if the neighbours dog peed any where near it.:)
   / Care to guess on a truck problem? #49
My 2012 Dodge Ram with about 80K on it is now on it's third Idler Arm, so I'm not sure anything is surprising to me with them. Since I had the repair done at two different dealerships (silly me thought it would be covered the first time at 60K), I don't think it's incompetence at the repair shop. Go figure.
   / Care to guess on a truck problem? #50
High wear is common - watch the ball joints too. Try Moog if you haven't already, those front ends will chew up low cost parts fast.
Rgds, D.
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2025 CATERPILLAR 275 SKID STEER (A52705)
2025 CATERPILLAR...
2014 Electric Cart (A53424)
2014 Electric Cart...
BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox XHD72...
1997 FORD BOOM TRUCK (A54756)
1997 FORD BOOM...
