Hard water deposits slowing flow.
   / Hard water deposits slowing flow. #1
Ed of all trades
Elite Member
Waynesboro Va
John Deere X310, JD LA 145
We have hard water and a few weeks ago the cold water in the kitchen sink was fine and then it looked like it had backing soda in it and the flow dropped to about 1/2. We replaced the faucet and it did not help. Anyone have this problem? and if so what did you do to fix it. I am stumped. It only effected that faucet and it is still about 1/2 flow. Thanks Ed
   / Hard water deposits slowing flow. #2
Do you have any cast iron in your system? Usually in fittings near the bladder tank or filters. Ours was 80% blocked with plaque. Occasionally a piece will dislodge and move up stream limiting flow.
Nope nothing but pex. Thanks
   / Hard water deposits slowing flow. #4
Try replacing the stopper valve on the cold supply. Could be a hunk oof lime build up moved to there and clogged. Another option is to turn water on at sink; then exercise the valve.
The stopper valve is an idea I will check it in a couple days when I get the chance. Mom's 91 birthday is Sunday and I need to go see her Saturday, it is when I can and church and my sister will keep Sunday busy. Thanks.
   / Hard water deposits slowing flow. #6
If you remove the valve , clamp some flexible hose on the pipe and put it out the window or outside and let the water rip and flush it out .
   / Hard water deposits slowing flow. #7
Or pull the trap and point it down the drain under the sink to flush the line. Did you replace the flex lines when you replaced the faucet?
   / Hard water deposits slowing flow. #8
I have issues with the cold water line on my clothes washer but never the actual house pipes, I take the cold supply line off and dump some iron out down it and that clears it up pretty well. I have used CLR in the past too but that didn't work as well
I think that Monday I will just cut the cold water line below the cutoff and clean up the bottom of the valve and put it back with a shark bite coupling. Be quick and easy.
   / Hard water deposits slowing flow. #10
Also try taking the screen flow restrictor off the end of the fixture ( where the water comes out).. They usually stop up & cause flow problems
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A52377)
2013 GMC Sierra...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2019 FREIGHTLINER...
1987 EZGO Golf Electric Cart (A53424)
1987 EZGO Golf...
Tradewinds Power Unit (A50120)
Tradewinds Power...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2017 JOHN DEERE 333G SKID STEER (A53843)
2017 JOHN DEERE...
