Max 24 newbee with starting exhaust question
   / Max 24 newbee with starting exhaust question #11
NE,
You are in a cold climate right now and I am not. I will say that when I heat up the glow plugs before starting I don't have the issue with black smoke. Mine will start w/o them, but it will smoke a fair amount upon starting and quickly go away. Even at fifty degrees mine likes the plugs activated...starts easier. A word of caution: the manual says to check the oil level every ten hours. My machine is new and at ten hours it was a full quart low. I know that it came full. Pretty natural for a diesel engine to use oil for awhile in the beginning as the break in period is longer than a gas engine. Check the oil!
   / Max 24 newbee with starting exhaust question #12
Just one of the benefits of having a real diesel tractor, not one of these fancy tier 4 things. It's a badge of honor within the diesel family. :)
   / Max 24 newbee with starting exhaust question #13
OP
If you are talking to me, and I am not too sure, then I would agree. Tier 3 here buddy.
   / Max 24 newbee with starting exhaust question #14
The new owner is picking up my little Kubota tomorrow, so I gave her one last workout grading my road. My new Max 28 sure smokes a lot on startup compared to the 30 year old Kubota. Even though the smoke on startup is "normal". I still find it odd that an old tractor blows barely a puff on startup and the new one belches.
Sorry I'm getting sentimental, but old tractors are like old dogs, you get attached.
   / Max 24 newbee with starting exhaust question #15
The Mahindras are so quiet that they purposely make them smoke on start-up so you'll know they're running. :)
NE,
Thanks JD. You were right by suggesting I check the oil. After 18 hours, the dip stick shows to add a quart.
1991 International 4900 Box Truck (A55315)
1991 International...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
48" Pallet Forks (A59814)
48" Pallet Forks...
2018 John Deere 1653 (A56436)
2018 John Deere...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
