Rear Hydraulics on a 2816 Mahindra
   / Rear Hydraulics on a 2816 Mahindra #31
Both T and T1 can be used as the return/t until you want to use PB.
I believe the PB adapter will go in T1 and that will separate the galleries so tank line will only pass cyl flow out the T port
T1 will now pass the pump flow, Carry Over /PB flow downstream.
With the PB installed, and going to the 3pt IN port, you now have full BH and 3pt operation.
Look in T1 port and see if there is a small 1/4 threaded hole or a larger hole with a flat face ring.
It will look like one of these.
I think the little hex screw is about 1/4 in.
J.J.,
My friend made the decision to just purchase the selector valve and go that route to get the BH up and working. We ordered two selector valves and enough hoses to complete both his Kubota and my Mahindra so either of us can oerate the BH.
THANKS for your help!
   / Rear Hydraulics on a 2816 Mahindra #33
If all else fails you can get kits for connecting up the backhoe and rear remotes for your tractor from Mahindra.
But you probably know that.
Powerscol,
Thanks for the info..
I am confident that the selector will work just fine, and for $150 including valve, hoses, and fittings it will cost a lot less. Will post the final result and how well it works
Randy
Parts came in, installed the selector valve and now we have the hoe working as it should and the tractor FEL works as it should. We select either the 3pt hitch or the loader.
The backhoe has an issue with one of the control valves ( bleeds off quickly) however everything else is working now.
Now how to fix the control valve.
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
John Deere 7000 12 R 30 Planter (A50514)
John Deere 7000 12...
2020 CATERPILLAR TL1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2011 Ford Explorer Limited AWD SUV (A50324)
2011 Ford Explorer...
