simplicity 3410garden tractor
/ simplicity 3410garden tractor #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
I need a wiring diagram for the engine/starting. tried to find one a while ago but it don't work. Any ideas?? Tractor is right around the 80s I would say
/ simplicity 3410garden tractor #2
can you describe the problem you are having someone here can help maybe is it starter or charging problem
2years ago I had a fire in the wiring. Kinda cobbled it but fix it then decided to redo it. Changed everything to new wiring and then when I hooked the battery cables when both were hooked it started rolling over and firing. Had to storage the tractor for a year and now got it out and started again fixing it
/ simplicity 3410garden tractor #4
if by some chance it is a starter/generator combo this is correct can you see any numbers on the starter this will help us i/d the unit as to what it does or possibly a picture would be most helpful.
Can do tomorrow. It's a combo. The generator/starter is good. What I need is a diagram to figure out the voltage regulator like the one I found and am going to try out
/ simplicity 3410garden tractor #6
most of these combos are regulator that are specific to the combo can you see if the unit has a delco number on it . if not let me know i will supply part numbers that are possible fits dont get scared they may only be about 3 or 4 numbers of which some are interchangeable
Delco?? Like modal
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
(3) STIHL POLE SAWS (A64276)
(3) STIHL POLE...
2025 Ligchine Spiderscreed Concrete Screed (A59228)
2025 Ligchine...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2013 Felling 25' x 102 Tag Trailer (A62613)
2013 Felling 25' x...
