simplicity 3410garden tractor
/ simplicity 3410garden tractor #1
farm boy00
Howard City, MI
John Deere M&MT, Case 1030 comfort king, Sears ST16, Craftsmen 6000, homemade articulation mini-loader
I need a wiring diagram for the engine/starting. tried to find one a while ago but it don't work. Any ideas?? Tractor is right around the 80s I would say
/ simplicity 3410garden tractor #2
can you describe the problem you are having someone here can help maybe is it starter or charging problem
2years ago I had a fire in the wiring. Kinda cobbled it but fix it then decided to redo it. Changed everything to new wiring and then when I hooked the battery cables when both were hooked it started rolling over and firing. Had to storage the tractor for a year and now got it out and started again fixing it
/ simplicity 3410garden tractor #4
if by some chance it is a starter/generator combo this is correct can you see any numbers on the starter this will help us i/d the unit as to what it does or possibly a picture would be most helpful.
Can do tomorrow. It's a combo. The generator/starter is good. What I need is a diagram to figure out the voltage regulator like the one I found and am going to try out
/ simplicity 3410garden tractor #6
most of these combos are regulator that are specific to the combo can you see if the unit has a delco number on it . if not let me know i will supply part numbers that are possible fits dont get scared they may only be about 3 or 4 numbers of which some are interchangeable
Delco?? Like modal
2012 Can-Am Spyder Motorcycle (A61574)
2012 Can-Am Spyder...
Year: 2018 Make: Towmaster Model: TC-16 Vehicle Type: Trailer Mileage: Plate: Body Type: Trim Lev... (A61567)
Year: 2018 Make...
74" X 49" TAILGATE (A64280)
74" X 49" TAILGATE...
2015 NEW HOLLAND BOOMER 41 TRACTOR (A64280)
2015 NEW HOLLAND...
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
1990 John Deere 755 (A64119)
1990 John Deere...
