Service fuel injectors on 3320?
   / Service fuel injectors on 3320? #1
Eric102
Gold Member
Pacific NW
John Deere 3320 John Deere X739
Was browsing the owners manual for my 2008 3320 and noticed that the fuel injectors should be serviced every 2 years, what the heck does that mean? Have never done it and the engine is running fine at 500 hours.
   / Service fuel injectors on 3320? #2
I haven't seen the manual, but my guess is the dealer checks the injectors for the correct spray pattern. Diesel, as you know, can be quite dirty and injectors are very close tolerance devices.
Just called the dealer and that's exactly what they do, check the spray pattern. But only on a as needed basis, such as hard starting or excessive smoke, not on a years or hours schedule. Mine has been fine in those departments so I'll skip it. It starts easily and the only smoke I see is sometimes when lugging the engine going up a steep hill when I should have throttled up or geared down.
On a related subject what's the preferred fuel injector cleaner additive to put in the fuel tank?
   / Service fuel injectors on 3320? #4
I don't use any additive. Figure the fuel I buy is good to go.
   / Service fuel injectors on 3320? #6
I use the John Deere "Keep Clean" additive
   / Service fuel injectors on 3320? #7
I've been using Power Service for years, but recently switched to Amsoil. Comes in 16oz bottles and only requires 1 oz for every gallons of fuel. Shipping adds to the price if order by the bottle(s), but if you buy a case (of 12) the shipping is free.
//greg//
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
Utility Cart (A59231)
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
