OP
sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,852
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I wouldn't bet the farm that the bottom weld was forgotten! When fabing with square / round tube a lot of people will leave a spot for condensation to weep out.![]()
The weld on the side that cracked does not extend around the rounded portion of the tubing sides. It stops short on the flat and I think that vibration from not being securely welded added to the problem.
On the good side that did not crack, the weld on the sides extends around the rounded portion of the tubing. That side did not crack is welded better. The only difference I can see is the way it was welded so that what sounds the best.
