Off-road diesel in new tier4 tractor.
   / Off-road diesel in new tier4 tractor. #1
Eliimbery
Freeland wa
Branson 3520r
Hello all. I just picked up a 2015 branson tractor with tier4 emissions (dpf filter) and was just curious if anyone had thoughts or experience running off-road diesel with the new tractors? Any issues?
   / Off-road diesel in new tier4 tractor. #2
The only difference between on-road and off-road is the die. The fuel is the same ULSD the you can find at any pump.
   / Off-road diesel in new tier4 tractor. #3
The only problem I have had with OR besides beig harder to find is that it doesn't sell as well and may be lagging to keep up with the seasons.
   / Off-road diesel in new tier4 tractor. #4
No reason at all not to run off road fuel, other than it will save you money!
   / Off-road diesel in new tier4 tractor. #5
Unless you have a problem with red dye, go for it!
   / Off-road diesel in new tier4 tractor. #7
Dye, tax, but off road has higher sulfur content is the main difference. if the engine runs ok you may have problems later, including the dpf filter. I would follow Mfg instructions
   / Off-road diesel in new tier4 tractor. #8
Do you have a source for that? That allegation has been made several times, and has always been disproved
   / Off-road diesel in new tier4 tractor. #9
   / Off-road diesel in new tier4 tractor. #10
Not here.
Buddy just got an $800 fine for using 'off road' on his private property in his tractor. (not even plated for road use)
In Quebec they call it 'stationary' rather than off road and only a generator is exempt.
He had a partial building fire and the insurance ordered him to empty the fuel oil tank to avoid spillage.
Where else but to use it in his tractor.
2005 CATERPILLAR 730 OFF ROAD WATER TRUCK (A51406)
2005 CATERPILLAR...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
Bush Hog 9670 8FT Pull Type No Till Grain Drill (A55218)
Bush Hog 9670 8FT...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2005 INTERNATIONAL 4300 24FT BOX TRUCK WITH TRANSLUCENT ROOF (A54313)
2005 INTERNATIONAL...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A51692)
2017 Mack GU713...
